  New Posts New Posts RSS Feed - My SMT212 CP755TI / SN12B
 Post Reply Post Reply Page  <1 45678 9>
wafflesomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 9:17pm
Does $500 sound reasonable?
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 9:18pm
Is that a single or the pair?
Away on extended leave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 9:26pm
For the pair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 9:33pm
4x Selenium 12PW3-SLF from partsexpress is $188.80
4x Selenium 12PW5-SLF from partsexpress is $297.60
I like the DR output from light cone drivers. Think JBL E120.
Edited by Deadbeat - 06 November 2008 at 9:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 9:39pm
I'll assume those drivers will perform well in the cabinet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 9:42pm
I've used the PW3 in a reflex and it had quite the HF response.
You might want to check on winisd of course.
Paulo Duto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paulo Duto Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 9:43pm
Hi
Made a pair of SMTs using a 12" Eros, Qt 0,35, Vas 65, Fs 50, Re 5,9, BL 16,90 Pe 350W, x-max 3,MM, Spl 95,2, and a 2" driver in the hf horn as in picture:
Crossed them passively around 1,6kHz and around 100Hz active:
Used the pair with four modified 1850.
Tried them out and put them in a corner; response was effortless good up to 16KHz. Low cut at 40Hz.
All I can say all me and audience were very well impressed with that little PA.
A closer view of the grills before attaching the foam:
Passive Crossover:
I recommend select a good woofer that work well BR up past 2Khz...
Regards,
Paulo Duto
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 9:48pm
The PW3 would work very well for my budget.  It looks like it's good up to 2k as well.  Polar's look good.
Now for the compression tweeter.  I assume I'll need something that will go down to 1.2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 10:07pm
You'll be wanting a horn to support that frequency as well. Take a look at 18sound's and Faital Pro's offerings on usspeaker.com
Use the search function if you want to know opinions on comps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 10:17pm
I don't think I'll be able to stick within the budget on the HF drivers and horns.  Oh well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paulo Duto Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 10:18pm
Hi
May I disagree?
Let's compare the curves of the woofers you refered:
Firstly the 12PW5 you can see the first peak around 350Hz and than the valley between 400 and 600Hz (-6dBs);
This driver is an upgrade from the 12PW3 (changed the aluminium dome for a paper one)
Now look at the 12PW3 plot,; this is an upgrade from the 12PW2, which present an analog cancellation mentioned of the 12PW5; they corrected (minimized) this but introduced the two big peaks when the dome sings (+6dBs between 1 and 2KHz and than a new valley at 2Khz returning to 0dB position, and than a Everest of +10dBs between 2 and 5 KHz).
This 12 PW3 was or is used for guitar boxes (how reproduce 600Hz?);
For guitar box may I suggest the 15PW3; made some boxes with succes;
Returning to SMT212 how about experiment the WPU 1209?
12PW5 qt 0,31
12PW3 qt 0,61
WPU1209 qt 0,32
Regards,
Paulo Duto
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2008 at 10:23pm
I presented wafflesomd with the two lowest priced drivers. You can't have a free lunch obviously as presented.
This page was generated in 0.234 seconds.
