  New Posts New Posts RSS Feed - My SMT212 CP755TI / SN12B
 Post Reply Post Reply Page  <1 789
Fracture_clinic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fracture_clinic Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2019 at 1:41pm
Originally posted by sushi sushi wrote:
hi! thank you for your answer! yes i can easily access RCF drivers..
honestly, i think the LF12G301 it's just too low freq, must be kickass for basses, but doesn't reach the 2.5 or 3khz where i need to crossover them..
On the contrary the MB12G301 can do the job perfectly: 72 liters is the lowest Vas i've found so far, probably works well in SMT's chamber! ...and the price is good for a 400w/98db RCF driver!
thank you for your advice! i think i'm going to try with the MB12G301, i'll also test the difference in performance between them and the Kappa12A.
oh right.. one point i was missing.. I'm going to use the SMT's on top of a kick section (2 HD15 loaded with Eminence Kappa15LFA) and a sub section (2 ESW1018 loaded with RCF L18S801) ..planning to double-up the rig, somewhen, and build other 2 kicks and 2 subs (or maybe sell the ESW1018 and build 4 WSX, in my porn dreams )
Yeah you're right to meet a comp well the LF doesn't really have the required specifications, I should have added that I'm going to be running an 8 inch mid driver between my 12 and 1.
If you're using HD's then absolutely use the MB not the LF!
I must admit WSX have impressed me in the past.. I think I just don't like their bracing though haha!
sushi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sushi Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2019 at 6:29pm
yeah, those round bracing are not nice, moreover are useless if you don't mount a protecting grille. i'll probably modify them, i'd rather have invader-looking braces on WSX's.. not going to look like the original martin audio, but i'm always honest about having a selfbuild rig (and proud as well)
cheers mate!
