  New Posts New Posts RSS Feed - My SMT212 CP755TI / SN12B
 Post Reply Post Reply Page  <12345 9>
roborg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roborg Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2008 at 2:06am
nice cabs, i used the same drivers in my mid-tops.  Are u gonna use your cabs in or around London soon, be nice to hear them? Those sn12b's are seriousaly nice drivers, even nicer with a phase-bung Wink.  I made mine out of 12mm to keep weight down, i used good old black aldrcroft, will add a couple-a more coats when i get back to them in a couple of weeks.
 I reckonned i spent 800quid a pair, so a very cheap cab for their performance.:
cheers,
  Rob.
Post Options Post Options   Thanks (0) Thanks(0)   Quote roborg Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2008 at 2:09am
hehe that cab got a bit mangled
login4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2008 at 11:01am
Clap i remember the build pics of those cabs, thats some great wood work mate,
did you ever do an A/B comparison one with phase plugs one with out?
ye i really like the SN12B's, very solid sounding and a bit of a steal if you ask me
wafflesomd, what Compression drivers will you be using?
Edited by login4 - 21 August 2008 at 11:07am
CELTIC SUBSONIC SOUND SYSTEMS
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2008 at 12:00am
hi guys,
if anyone is interested ill be taking out the SMT's this weekend to:
Grass roots festival (muddy promotions)
http://www.thegrassrootsfestival.co.uk/
the festival is held near peterborough and ill be on the Circuit Tree stage, come have a listen it would be great to meet some peeps off here...
jonny4288 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonny4288 Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2008 at 9:36pm
just noticed you had them at workhouse festival, only 40 mins down the road from me.
you doing anything else local soon, im stuck on what im going to use for midtops for the rig im putting together,  would like to listen to a few differnt tops to get an idea of what will compliment the rig best.
x1 letterbox with 4 hd15's and 1 or 2 midtops per stack. just building the 1 stack for now though.
will mainly be used outdoors in ruthin/denbigh area (clocaenog forest)
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2008 at 12:12am
 hi jonny,
iv been to some good woodland events up thereWink
im not sure when the next time ill be up that way but ill be sure to drop u a pm if i do.
in your system id say something fairly small like a porn horn type cab should do it,
i haven't tried my SMT212's above a kick section yet, i dont feal they need it but ill look forward to the results.
last outing the other week:
(fish eye)
wafflesomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2008 at 3:00am
I havn't decided.  I'm currently searching for drivers on a budget for these cabinets.  I should have built some X12's.  It's hard to find a driver for cheap that will work well in these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2008 at 7:14pm
perhaps a p.audio BM D740, 1.5" exit
djstefanos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2008 at 8:20pm
do you have issues with balancing when lifting up from the flush handles?
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2008 at 8:25pm
wafflesomd, try selenium as well for comps.
Edited by Deadbeat - 03 November 2008 at 8:25pm
Away on extended leave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2008 at 8:38pm
they are a little top heavy with that monster comp driver in but its not too much of a problem as i put another handle on the back of them too this also helps for going up stairs as the one going up first can grab the handle with one hand.
i would advise putting the side handles a little higher than i did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2008 at 4:11am
Do you think that P.audio will keep up with two Emeinence Delta's?
