  New Posts New Posts RSS Feed - My version of the X-tro and Punisher
 Post Reply Post Reply Page  <1 161718
G-Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G-Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2009 at 9:26pm
I like the cross firing mid design, good job. Looks good also.
If it was easy, everyone would do it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2009 at 8:02am
What are the 8's? Is the 8 section louder this way?
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2009 at 9:05am
they look like fane?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2009 at 10:50am
P-Audio also had some frames like those.
darkmatter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darkmatter Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2009 at 4:26pm
Marjan I imagine the 8" section is slightly less sensitive but will handle more power.
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2009 at 4:48pm
the dual 8 section is based on a modified version of an existing P-audio driver
They are not available to the general public
the closest equivalent would be the S8-38M
the configuration handles loads more power than the initial variant and is definately louder (about 6 dB louder than the S8-38M in a wooden horn)
the V configuration also gets rid of beaming ,
Ex Nexus_3
LjudLahger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LjudLahger Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2009 at 8:24pm
V configuration is the best Thumbs Up nice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2009 at 9:56pm
although , not evident, the V configuration is  the simplest way of making the emissions center of the two speakers as close as possible without needing smaller cones
in this configuration , the mids stay perfectly coupled until 1200Hz which is the crossover point to the compression driver
Ex Nexus_3
puffah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote puffah Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2009 at 10:11pm
I lost touch with this thread for a little while since I have not had much free money around to build. I'm glad to see the design get pushed  along. I have been waiting two years to build mine.  I think I am going to go the p audio route because of wattage reason.  Its matches my amps better. I love the idea of the 2 inch horn and the double mid. Better to have more then you need then see people taxing and blowing things out.... I am thinking this same extro and then 3 punishers under each side, using the p audios. The p audios are a little more in the us. I can get lab drivers super cheap but I like the size of the punishers
vicious bass since 1988
seigmann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote seigmann Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2014 at 10:06pm
Hi,
Does anyone have a drawing on the double 8" horn? I want to make one.
They sound better than the orginal horn?
Panda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Panda Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2014 at 2:07pm
Originally posted by seigmann seigmann wrote:
Hi,
Anyone? I'd also like to know how to do this?
