  New Posts New Posts RSS Feed - Need a little advice before I over commit
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2020 at 10:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2020 at 10:30am
Originally posted by Pigeonkid666 Pigeonkid666 wrote:
I've heard that when you underpower speakers that there's some not so good distortion... considering there 500w max across 1 8" woofer and 2 piezo (one square, one horn) a easy 250+250 should do it considering the ohms will be different? It's at 8 so I assume it'll drop to about 4 a channel which is piss easy to power right? And if I'm gonna underpower them would be best to stick about 150+150? Thanks guys this is helping I know I'm slow asf
Underpowering does not cause distortion.
your two 8 ohm speakers become a 4 ohm load when wired in parrallel
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2020 at 3:22pm
That Lanzar amp is, again, class AB - meaning it is not efficient, and will waste an annoying amount of your battery power in heating up the large, heavy heatsink on it!
The Pioneer is class D, so it will not waste as much power, and is guaranteed to be lighter.
It also has a very useful built-in crossover - so when you get a bass bin, you can use that to separate the frequencies. You can also use it to cut very low bass from your Skytecs, so you don't waste power sending them frequencies they can't play. With the Lanzar, you would need to buy an external crossover of some sort to do all of that, which is an extra expense.
Pigeonkid666 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pigeonkid666 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2020 at 3:54pm
Yeah your all defiantly right I'm probably gonna buy it tonight, thanks for all the help everyone!!!
