  New Posts New Posts RSS Feed - ...need enclosure propos.
Rainer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rainer Quote  Post ReplyReply Direct Link To This Post Topic: ...need enclosure propos.
    Posted: 16 May 2006 at 3:45am
new bass is needed. It should run up to about 700Hz.
Alt.1
2x12" precision devices PDN.12SB40/PDN.12MH25 or 12"-Neodym.   from RCF
Alt.2
2x15" precision devices PDN.15BR40/PDN.15SB40 or RCF LF15N401
Does someone have experience with these drivers? What enclosures could be used? Thanks for some ideas!
Dave Slater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2006 at 4:20pm
no direct experience of any of them but i have been playing around with the PDN 15SB40 and i can tell you they model very well in short horns
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rainer Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2006 at 3:03am
Hi Dave,
thanks for your reply.
background for my new bass is: I have a very good wooden mid-horn, that goes down to about 700Hz. Therefore the bass-unit has to run up to that point.
I think, a pure short-horn-enclosure cant be driven so high. The bass is for home-cinema-purpose. perhaps a mixture of bassreflex with good connection to air and horn or some type of bandpass-design should be better. My problem is, no enclosure-proposual fo find at all of the producers, nor in forums
