  New Posts New Posts RSS Feed - need help finding modular amps
Jay Lawless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Topic: need help finding modular amps
    Posted: 27 August 2005 at 2:39pm
  I need some help finding a Modular amp for some active cabenits. I'm trying to find one that is capable of supplieing 800-1,200watts at 8ohm operation mono and it needs to be 120V because of American plugins . Anyone know where I could get some here in the US? Or at least some Modular amplifiers around 400-600watt 8ohm? The higher the power, the better for subwoofer use .
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 27 August 2005 at 2:47pm
With all due respect, probably not worth the bother.  It'll be cheaper to use passive cabs and external amps.
I'm still not sure why active cabs are getting so popular.  They involve running so many extra power cables and offer no redundancy in event of failure.  You'll still have to run an active processor as you'll struggle to find/afford a passive filter capable of dealing with that power.
Of course thats how i feel about them, maybe better someone who likes them should advise you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 27 August 2005 at 4:25pm
Well I do understand why some don't like active cabs. I like the idea because the amplifier is with the cab instead of in a seperate case. Cables don't cause much trouble for me, it's a compact highpower system. I can deal with big cabs and active cabs, but I really don't care for carrieing a 110 pound case full of amps   . Caster cabs are more suitable for me .
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2005 at 10:49pm
Im trying to find a link,that was to a US based company that did this-I think Wayne mentioned it on audioroundtable.com...
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 31 August 2005 at 10:52pm
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&P artnumber=300-808 1024w rms into 4 ohm, subwoofer plate amp
A high powered subwoofer plate amp is what you need. Just not many are fan cooled, but do have massive heatsink fins on them though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2005 at 12:26am
Neverwinter,id ask wayne parham nicely he might still know the link to that prosound sub amp site.
Toxic : I just would never trust it fullly,I mean I dont trust my own 350w plate amp for home use! Gota remove the EQ on it too argh
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2005 at 4:55am
I like that amp Toxic, only problem I see with it is that the heatsink fins on the inside, not the back. Causes a problem with heat in horn or sealed cab would'nt it?
@td_mike, where would i find this "Wayne Parham" ?
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2005 at 5:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2005 at 1:41am
www.pispeakers.com 'forum',ask nice hes a good guy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2005 at 1:42am
Originally posted by mykey mykey wrote:
www.renkus-heinz.com/amplifiers/pn.html
www.renkus-heinz.com/amplifiers/pm.html
www.kv2audio.com/es_epak2500.html
loadsaaaaa monnnnney!   i should imagine
renkus heinz gets me all worked up
KV AUDIO! a local band 'shapeshifter' use their gear on tour everytime,and a club now bought some. Interesting since NZ is quite limited range,most just go for martin audio or overpriced JBL.
Quite high quality gear from what ive heard down here.
Edited by tb_mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2005 at 1:49am
@tb_mike
if you ever go to Bali ( on your door step) visit the famous 66 club they have kv2, sounds nice, great bass but not enough of it for my taste
Edited by mykey
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2005 at 10:12pm
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&P artnumber=300-752
Heres one with heatsink fins on outside, but it's rated 500w rms into 4 ohm though[less than other one].
