  New Posts New Posts RSS Feed - need help from the electrical lads!
Jay Lawless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Topic: need help from the electrical lads!
    Posted: 19 October 2007 at 10:35am
I have a small non audio related project going... but it seems something from the world of sound has come up in my project.
a Pulse Width Modulator is what i need to be precise.
how difficult would it be to design/build a PWM for 0.5amp to 15amp at 12v operation targeting adjustable frequencies from 10,000hz to 47,000hz? power supplied is 12v DC current from a car battery/alternator *so that means 10v - 15v tolerances*.
any advice to this at all?
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
tommysb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommysb Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2007 at 11:21am
What are you doing with it?
My housemate built one in an afternoon. Can't be that hard!
If you're modulating a signal, you compare the signal to a sawtooth wave. If you're just using it to control rate or something, well i suppose it's the same actually, but just vary the triangle wave frequency or the level going into the comparator.
I'd do it as a 2 stage thing, get the pwm signal at low level, then amplify it. No reason for this, other than it'd be easier to test/prototype.
