  New Posts New Posts RSS Feed - Need help with X15!!!!
jac2003 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jac2003 Quote  Post ReplyReply Direct Link To This Post Topic: Need help with X15!!!!
    Posted: 11 May 2005 at 12:19pm
Hi,
I will open a bar/cafe in Shanghai. Due to the high price of well known intl brands here and unavailibility and low quality of some local brands, I have decided to build some loudspeakers myself.
We have a 250 sqm (about 2500 sqfeet??) location with a high ceiling and we need to play a wide range of music and also some solo performances now and then)
I though I might try to build the X15's myself since I'm quite experienced with the cabinet part - but I know nothing of speaker design.
Anyway, with some luck I found the P-Audio distributor in China and  ordered the following components:
sn-15mb woofers, bmd 750 compr drivers, ph-3223 flares.
I got it for a very good price ($65, $60 and $25 for the above!!) but i know that the hf driver is different from the one in the plan.
Here's my question:
Will it work with the bmd 750?
What do I do regarding crossovers?
Thank you very much!
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2005 at 12:44pm
Try mailing proaudioparts for a recommended crossover for the SD-740 + 1.5"-2" adaptor on the same horn. The response of this combo is likely not the same, but you might get useable results. That's blooming cheap if I may say so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jac2003 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2005 at 12:56pm
Thanks broer,
I will mail them. Just one more question - what subwoofer option from this site would you recommend for P-Audio drivers, if posible.  I really need something that's not too big.
