  New Posts New Posts RSS Feed - Need plans for earthquakes.
rackmount View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rackmount Quote  Post ReplyReply Direct Link To This Post Topic: Need plans for earthquakes.
    Posted: 05 June 2007 at 8:36pm
 Could some one help me find plans for Cerwin Vega Earthquakes.
Thank you
DJ Coupé View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Coupé Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2007 at 9:17pm
SL36 or B36 or.....
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2007 at 9:39pm
Thank you
Read below thread "entirely" before building anything.
http://www.speakerplans.com/forum/forum_posts.asp?TID=9757&PN=2
Would be nice if you compiled the dimensions from all the given plans
onto the AB36 diagram and posted it here.
Regards.
basscreator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote basscreator Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2007 at 11:36pm
think these are the origional design....
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2007 at 11:53pm
The best "Quake" boxes are all 36" deep, 24" wide and 36" tall.
That design is one of the castrated 24" deep throw backs.
The AB-36 is best of the lot. has SL36B design, with Angled Metal chamber plate as heatsink, and slightly better driver than rest of series.
This is the one that needs to be Built and Bionic'd with Upto date driver.
Edited by levyte357 - 06 June 2007 at 1:38am
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2007 at 10:15am
Lev
Do u rekon the loonie bin should have a heat sink to make them more efficient, infact all horn cabs !!
Why not make the 186 Horn, rackmount !
Sticks n Stones
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2007 at 10:47am
Originally posted by CHAMPION CHAMPION wrote:
Lev
From what I understand, the metal plate "heatsinking" just dissipates heat to lower compression. Maybe Rog doesn't consider heat to be a problem with loonies.
But if someone wanted to make aluminium backplate like labsub, I'm sure it is a  minute change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rackmount Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2007 at 7:09pm
 Thanks all, I am looking for the plans for the   L36pe, they are 36X36X24.
I allready have two but would love to build two more!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rackmount Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2007 at 7:33pm
 The reason for two more is that I heard that four couple better, can some one please explain?
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2007 at 9:58pm
Search "horn coupling" or similar... should be plenty of explanations here for that one...
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 07 June 2007 at 11:05am
Lev
A 36x24x36 vega horn with additional bracing and top notch driver will drop deeper than 186 horn.
Modelling to confirm.. soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 07 June 2007 at 11:18am
what driver, if it drops lower, will it throw the sound any better ? also how will they respond to different types of music, house, garage, etc
Sticks n Stones
