  New Posts New Posts RSS Feed - Need tight Deep Bass box
shehantha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shehantha Quote  Post ReplyReply Direct Link To This Post Topic: Need tight Deep Bass box
    Posted: 06 August 2014 at 3:46pm
Hi, I am new to this forum. I went throught all the desing in the speakerplans site and now confused. I need to build 2 boxes for my SR707 amplifier. I need a bin which gives DEEP TIGHT BASS ( chest hitting punch ) So which design is good for me. I plan to put P audio SD.
Is 1850 ok for me ? of X1 ? or G type bin?
Please help me. Few of my friends said horn type and subwoofers gives boom bass . means bass with little eco.Is that true. Because I have never heard the sound of X1 or 1850 horn type boxes
Thanks
Shehantha
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2014 at 3:59pm
the bins you picked are more suited towards booming as appose to pounding...i THINK your after kick bass instead of sub bass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2014 at 5:50pm
What is SR707 amplifier?
Adam_Iron_Horse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2014 at 5:53pm
C-audio sr707
Kryptonik Sound Kollective
www.facebook.com/kryptoniksoundkollective
Post Options Post Options   Thanks (0) Thanks(0)   Quote shehantha Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2014 at 5:55pm
yes correct C Audio SR707 at 4 ohms in bridge mode they provide RMS 2200 W
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2014 at 7:36pm
And when running at 4Ohms bridged, you can also use them to cook your dinner!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2014 at 1:12am
^^ Can confirm this. Worrying but was pretty sure it would be fine all night at roasting hot temperatures.
It was when it and the peavey cs1200x underneath it got together was when the problems started haha
Post Options Post Options   Thanks (0) Thanks(0)   Quote shehantha Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2014 at 5:58pm
Please can someone give me a serious reply .
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2014 at 6:18pm
In order to get a serious reply you need to ask a serious question!
Your question translate quite similar to this. I need a luxury and very roomy 4 door sport car that i can use on the race track, but also use it as a limo service on occasions.
Depp bass, and punchy bass are two different bass characteristics. So chose your weapon. Tight and punchy or deep.
Both are possible only with reflex subs.
Edited by MarjanM - 07 August 2014 at 6:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2014 at 6:55pm
...your on the wrong forum mate! Lol
Reflex will get you a good 2 octaves of bass, long and short(er) horns will get the same result but with two cabs
Edited by mini-mad - 07 August 2014 at 6:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shehantha Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2014 at 7:24pm
Thanks for the reply. Does es18bph will suit me ? Sorry for asking my question in confuse way. I need chest punch feeling box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2014 at 7:25pm
Normally, you choose the cabinet first, then the best driver to load it with, then the amplifiers.  You seem to be looking at things the wrong way round.
Best advice I can give is to go and listen to some systems, decide what you like the sound of, then come back and we can help you select the DIY cabinet which is the closest match.
