  New Posts New Posts RSS Feed - Neodymium drivers in Scoops
 Post Reply Post Reply Page  <1234 6>
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 8:04pm
Originally posted by luton_soundman luton_soundman wrote:
U want lows from a 50 put it in a better scoop. Put a 50 in a smini or the sb version i had. And then compare that to your big chamber/throat box. Then the difference isnt as big. But no point comparin that b&c to a 50 when theres a 51. 21" wise the 18sound is stronger than the b&c so id bet thats the same for 18" too.
There's so much bandwagon jumping, and follow fashion these days Luton, many people don't take the time, to design boxes for drivers and evolve them to high perfoming cabs..
I developed box for '52 class drivers, but no one really developed boxes for '51, so only few know which boxes '51 excels in.
I have prototype sitting in unit, waiting for testing with '51 for months. LOL
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 8:06pm
get your hands on a 18ds115 lev, should outplay the nlw9601 in dedicated scoop or looong FLH ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 8:12pm
Parameters look good, but looks like it won't fit in the Scoops, it would be perfect in!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 9:26am
I wondered this my self too, but somehow i still prefer the 5.3 inch voice coil.
I never compare just the TS, need to try it side by side.
EDIT; I just simulated the 18DS118 against our custom 18NLW9601. So no, it does not outplay it by any means. It has exactly 1db lower sensitivity then 9601. Response is virtually identical.
Edited by MarjanM - 15 May 2017 at 9:33am
darkmatter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darkmatter Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 4:21pm
Maybe it's something to do with: in a smaller box, a neo driver noticeably reduces weight. In a scoop, a neo driver means a two man lift is... still a two man lift.
Also, in a box that is commonly built at home or within the DIY community, a neo driver is a very large proportion of the total cost. In a commercial box (i.e. generally not a scoop) this applies a little less.
turbo7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turbo7 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 10:24pm
BL = 39 T*m, real xmax = 13mm, clever motor system too, its better than the 18s, if you go really low with large excursions this driver will always play with lots of coil in the gap ! Edit: cooling should also be better for the coil, trade off might be the copper clad alu 4,5 inch coil ! Has to prove that it can take the heat
Edited by turbo7 - 16 May 2017 at 10:33pm
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 1:22am
Anyone heard/tested the 18ds115 on here yet ?
Soo 39bl would mean the driver has a monsterish motor , fast as it can go?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 8:08am
If it's anything like the 18SW then it can
Post Options Post Options   Thanks (0) Thanks(0)   Quote turbo7 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 12:30pm
" EDIT; I just simulated the 18DS118 against our custom 18NLW9601. So no, it does not outplay it by any means. It has exactly 1db lower sensitivity then 9601. Response is virtually identical."
in which cabinet did you sim the 2 ?
high damped drivers can make very strong notes down low, this one has ca. 3mm more x-max than 9601, more BL means also more control at high power levels and can receive way more eq to flatten things out without stress for too much cone movement. Still, the 4,5" coil is what makes me nervous a bit, also. Did anyone blow a SW18 and how ?
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 3:18pm
It has a 4.5 inch coil but they also state its lenght which is 40mm. I cant find this info for other drivers. If they bothered to put it up surely its different from the others.
Edit: is that winding depth?
Edited by Sypa - 17 May 2017 at 3:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 5:43pm
I have tried believe me. Thought I had taken one out last week, but it had just undone some M10 mounting bolts on the box and you could hear them rattling
Been giving them full force of a K20, two 8 ohm drivers a channel. No hassle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote turbo7 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 5:48pm
Yes Sypa, that is how to calculate x-max ( there is no real calculation for xmax imho because every driver is different and the important thing is how it behaves when the coil leaves the gap partly ), that means (40mm-14mm)/2 = 13mm
"Been giving them full force of a K20, two 8 ohm drivers a channel. No hassle."
damn i need mine now !!
Edited by turbo7 - 17 May 2017 at 5:50pm
