Neodymium drivers in Scoops |
Post Reply | Page <1 456 |
Father-Francis
Old Croc Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2760 |
I done a box with pd 2151/2150 , 2*1850 are louder but don't go as low
So the whole thing comes to you looking to play 35-7hz 6db higher or deeper on your subs . Every time you take 4boxes I take only 2 . Even if you tak 2*18 , I'll take 1*21 for each box you take. |
Teunos
2x18 will be louder for sure.
There is something called power conpression as well to keep in mind. That said 1x21 can be 8" while double 18 is typically 4 so if you have the amps to power them (think k20 etc) then single 21 might be wiser. |
Best regards,
Teun. |
Crashpc
Registered User Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 463 |
Father-Francis: True. I still want to go ba(ll)ss deep, so it seems I´m staying with 21". I don´t need to go any louder. The 21 is overkill in the upper range for me, but not at 25-30Hz, soooo I might stay.
I wonder if DS versions will handle the same power as 18SW115, because the coil is Al now, not copper. I´d say it wont, but in specs, B&C says YES :-) Teunos: It´s true that the displacement volume is the same, as with ordinary 18" as 18TBX100 or 18NW100 is. So down there under 50Hz, 21" has great chance to do the same. In the 60+Hz range, two 18"s will have the upper hand, but I don´t need it really. I must also support the efficiency discussion. More motor force and displacement volume wins. Sensitivity comparisons are useless in HR. |
