Netgear RangeMax NEXT WNR854T |
Author | |||||||||||||||
djstefanos
Old Croc Joined: 18 November 2005 Status: Offline Points: 2355 |
Posted: 03 April 2009 at 2:23am |
I just bought this off ebay. Refurbished Item is what it said on the listing but it came in an original box, everything brand spanking new.
I hook it up with my cable modem. Modem lights up all green as well as the router meaning that its sending a signal to the router. I have a static IP address. In my previous routers I never had to set anything. I've always set it as default(except for the wireless security of course) so pretty much plug and play. I get no internet in any PC in my house. I don't know whats going on. Either wireless or ethernet. I've also tried fiddling with the IP settings, copied numbers everything off my other router. But I still get not Internet. PC's seem to connect to the router without a problem, launch IE or FF, i get jack s*** Please help Edited by djstefanos - 03 April 2009 at 2:30am |
cravings
try put http://66.102.9.147/ into a browser
if you see google.. it means your DNS settings are wrong. there's a start for you.. |
djstefanos
I'll check it when i return home soon, thanks, will post my results.
Rockin
Young Croc Joined: 02 April 2007 Location: Rotherham Status: Offline Points: 737 |
When you goto your router page...
http://192.168.0.1/start.htm Does it show that you are connected or not? Example below
Edited by Rockin - 03 April 2009 at 9:41am |
nickyburnell
This is a CABLE router.
As long as the router is set to defaults it should just find the ethernet from the cable modem.
Try resetting the cable modem with the router switched on.
djstefanos
fixed the bloody thing,
flashed the firmware. thanks guys :) |
