  New Posts New Posts RSS Feed - Neutrik NL8 no screws provided just copper sleave
PolymorphicMark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PolymorphicMark Quote  Post ReplyReply Direct Link To This Post Topic: Neutrik NL8 no screws provided just copper sleave
    Posted: 16 June 2025 at 9:23am
I've purchase some Neutrik NNL8 speakon connectors but I was rather bemused to find there are no screws and clamp like my old ones. There is just copper sleeves in the packet and no screws in the terminals.  How do i connect the cables?
Units came in Neutrik packet so I presume they are genuine.
Mark
Free to do what i WANT
Lucasdude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lucasdude Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2025 at 6:25pm
If its NL8FC, then it certainly should have grub screws. The old ones were Allen heads, the later ones Pozidrive. You can tin the bare wires, and solder through the threaded hole if you're desperate!
HumbleDeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HumbleDeer Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2025 at 9:00pm
And the new ones after the Pozidriv ones, are Torx t15
Post Options Post Options   Thanks (0) Thanks(0)   Quote PolymorphicMark Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2025 at 12:16pm
Just noticed they are grub screws that are screwed all the way in. Did not see them when i was doing my wiring late in the evening.
Old man doggy eye sight Smile
Mark
