New amp |
Post Reply | Page <1 2345> |
Author | |||
U.Viktor
Young Croc Joined: 04 May 2010 Status: Offline Points: 716 |
inuke is not a professional kind of amplifier.
It does not even have load independent frequency response, it hurts my ears with most type of mid/high speakers.. |
nickyburnell
I stand corrected, you said subs. It really wasn't offensive Ray, just banter |
nickyburnell
I heard them on berry mid tops, nazel, but who knows what was going on behind scenes. Back better this morning, heavyweight s live on.
levyte357-
Cool, no problem. |
midas
Old Croc Joined: 27 October 2011 Location: Cumbria Status: Offline Points: 2117 |
Berry tops sound crap.
No need to panic Matrix on top duty. Just in case anyone is interested and puts their handbags down for long enough. Edited by midas - 20 November 2017 at 2:52pm |
levyte357-
Matrix do sound great on mids/tops, but find Behringer more reliable. We did gig 2x weeks ago, Approx 1200 people, 8x subs, 4x 2x15 kick cabs, 8x MTs, Bullets. Berry Inuke 6Ks/NU4 6Ks on kick upwards, Berry 12Ks on sub. BSS LMS, mids tops, clean, bright, sub warm and deep. No complaints. This is why sometimes what is said here about amps, can be dismissed as personal opinion. Go hear/try stuff for yourself, make your own mind up. |
midas
Think you miss read that.
Berry tops sound crap. Not berry on tops sound crap, I have never tried them on tops. I like the sound of Matrix on tops, qsc, pkn. |
levyte357-
Cool.. I don't own any Berry amps, I just tune my mate's set, to get best sound, out of what he has.. He does around 5x gigs per month with big set and Berrys, so they have paid for themselves, many times over, |
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5172 |
I own the Peavey PV 2600. I would never consider operating this amplifier on a circuit smaller than 20 amperes (120-volt line source) unless, I don’t mind achieving half of its rated power at any given load. The voltage requirements that list 1/8th of a power is fine for live music however, unacceptable for pre-recorded music.
Best Regards, |
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1173 |
Please explain why the amp will only achieve half its rated
power? The breaker on the rear of the European 220-240volt version of this amp is 7.5Amp, so the maximum continuous power draw of this amp is 1725 watt @230V (or 1800Watts @ 240V) before running the risk of the amp’s breaker coming out. The 120V version has a 15amp breaker; so again, the maximum power draw can only ever be 1800 watts continuous before risking the breaker coming out. If the amp is NOT delivering the specified power (and not popping the breaker) I would have thought it was because the 120V supply is not stiff enough and the incoming voltage is sagging under load, this is hardly the fault of the amp and more to do with inadequate cable sizing in the installation. The Power draw at 1/8th output power spec is how Peavey specify in the amps manual, not something I’ve made up, personally I’d use the 1/3rd power rating!! |
Amplifiers receiving line voltage sag is common with everyone that uses multiple amplifiers playing the same frequency band. The only ways to prevent such sagging is the have a stand alone voltage regulator or have amplifiers with an on-board voltage regulator that can build up the loss voltage from the A.C. Line Source.
When Peavey Amplifiers attain less than adequate current the amplifier will either premature clip or trip the breaker. Old Crown amplifiers were notorious for following the same type of behaviour in addition to Crest.
I have actually benched the PV 2600 under a 15 ampere circuit and the amplifier would not meet its advertised specifications. It is only when I used a 20 ampere circuit the amplifier met/exceed its advertised specifications.
It does not matter what class the amplifier is designed under. All amplifiers are going to consume more current when needed to deliver the output voltage at the given load.
Best Regards, |
Tonskulus
Registered User Joined: 15 September 2017 Location: Finland Status: Offline Points: 425 |
Oh, well I didnt blame you but rather those manuals giving some weird figures of input power.. because it really depends on what kind of music we play. Some basic trance music, up to clipping = averag input for 6kW amp might be just 1kW. Now let's take some dub tracks with really low frequency, long bass lines. Average power increases to 3kWatts. Just as example.. I have blown some 10A breakers using 2 x 1500Wrms class ab amps w/ dubstep :D I measured input voltage decrease from 223V to 215V. Surely amplifiers could not deliver the stated output power in these conditions. We really need heavy power wiring (16A rated) for these big amps which usually means 2 x 2.5mm2. Here in Finland, 1.5mm2 wiring is standard for 10A breakers. Long runs having only 1.5mm2 really does make some voltage losses when pulling some amperes out of it. |
