  New Posts New Posts RSS Feed - NEW CELESTION 24" DRIVER
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2024 at 7:06pm
The price can be found through the Link.
It's around the same price as most 21 inch drivers.
Best Regards,
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2024 at 8:44pm
Aside from the eminence 21 its definatly not around the same price as most?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2024 at 9:49pm
They are very similar from a TS Parameters standpoint. The B&C 21SW152  also offers very similar TS Parameters with a competitive price point in the United States.
Best Regards,
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2024 at 9:44am
celestion on fire atm. will probably be good and maybe a bit different from b n c offerings? worth it though? maybe not
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2024 at 3:15pm
£995 for the 24" and £525 for the 21". I think you can guess where my money would go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2024 at 10:54pm
Yeah i expected the price to be lower. Although the specs are better than the PD most people will choose PD over them just because of the brand. Hopefully trade will be alot more attractive
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2024 at 4:35pm
FK1 moving to use Celestion it seems. Hence the new range and 24" to replace PD24...
Just my ten cents.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2024 at 5:28pm
fairly sure there have been celestion bits in various fk1 stuff for quite a while now
Crashpc View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2025 at 8:47pm
Anyone?
Soo, ordered a 4Ohm version. Already shipped. Clap
Lucasdude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lucasdude Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2025 at 9:35pm
Sweet. My current system is all Celestion drivers. If I can scrape together the £1150 I might consider getting one of these and knocking up a simple reflex cab for it. I'm sure a bridged Crest CA18 will give a single  4ohm one a good workout!
Edited by Lucasdude - 09 October 2025 at 9:36pm
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2025 at 4:10pm
I'm not so sure.
Good luck powering 4x of these, in UK venues with only 13A plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2025 at 8:05pm
I might be wrong, but I think that is bogus data. The 24" data presentation says something like *simulated on their webpage, and also the figures were questioned and some (maybe on other drivers, I donĀ“t care to remember) were corrected. While noone attacked these on this particular driver, these might not be corrected. Celestion did not show exactly best interest in this department. Or at least I see it that way.
