New DJ Monitors. |
Page <12345> |
| Author | ||
TONY.A.S.S.
Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6867 |
Posted: 18 April 2013 at 6:26pm |
I get a more open sound out of my horn than I would with a little horn in the Co-ax's. I prefer to have a horn that you have to turn down. The Horn is the same as I used to use in the Reflekta MX900.
jbl_man
Joined: 12 January 2005 Location: London. Status: Offline Points: 11308 |
Posted: 18 April 2013 at 6:47pm |
Lovely looking cabinets Tony,memories of Glitter systems finish there,now all you need is gold,metalic black and purple.
burningbush
Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5885 |
Posted: 18 April 2013 at 9:16pm |
I've just noticed the gold grills, cool!
TONY.A.S.S.
Posted: 18 April 2013 at 9:38pm |
The Grills aren't finished yet, they'll be a lot brighter after tomorrow, as will the Horns.
bee
Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4549 |
Posted: 18 April 2013 at 10:22pm |
dare i say it Tony but they look very joey essex....
![]() as allways tony i love your wood work pure class.....
Autograff
Joined: 22 October 2008 Location: Sheffield , UK. Status: Offline Points: 1361 |
Posted: 19 April 2013 at 2:58pm |
As a DJ I prefer active, I feel I have the control of them, and I know there won't be a single bit of delay between them and FOH, so I know my mixes will be ok.
Liquid_Steel_Sessions
R8 Records |
mk2_ginger_biscuit69
Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7797 |
Posted: 19 April 2013 at 3:39pm |
not wishing to be argumentative - but surely as electronic signals travel at [~] the speed of light, there would be no measurable delay between active, and passive... and you will probably find that the foh IS delayed on most systems.. most modern rigs involve horns and delays by design, and any distance between your position and the FOH, and the monitors providing they are at a different location, will cause two different delays relative to your ears And regardless of that, it doesn't matter, main thing is your monitors are are close to as possible to your decks time, not FOH! That's what you are mixing. |
TONY.A.S.S.
Posted: 19 April 2013 at 4:41pm |
Interesting comments about active or passive. Here's what I think. I only assume that a monitor has to be flat, and if you can achieve that with a passive x/o, then you've cracked it. A sound isn't purer just because it's active. Some of the best sounds you'll ever here in Hi Fi are through a passive x\o. With a multi section PA and taking into account the power, active systems are essential. Regarding monitors, You can't think of being active so that you can tweak the balance. The only balance needed is a flat response, or as near as you can get it. For those who think Monitors should be active, I would like to hear why.
biotec
Joined: 07 June 2004 Location: United Kingdom Status: Offline Points: 2932 |
Posted: 19 April 2013 at 4:42pm |
great job Tony!
I did something similar for a little coaxial driver a while ago: http://forum.speakerplans.com/topic69822_post694678.html#694678 I had a load of 6.5mm plywood leftover from another job and so I kerfed it to get it to bend tight enough. Did you use multiple layers of thinner plywood? 3mm? |
TONY.A.S.S.
Posted: 19 April 2013 at 4:56pm |
Just took a look at your cabs, great job, I remember seeing them first time around. I actually used 8mm Flexi-ply. The original idea was to wrap the first layer and then use two sheets a fibreglass, and stick the last sheet on to the glass. After the first sheet went on, I became aware that it was very taught and the resonance was high. I was really surprised, Anyway, I thought I would take a chance just to see how it would sound. The next day, I had second thoughts because the grain around the tight bit at the back seemed to be opening up, so I thought I would then paint it with Resin, which would cure it. And then I thought, why not fiberglass the inside, so that's what I did. It is a really solid structure now with just 8mm ply and glass. I had also taken out all the screws around the top and bottom so that I could Radius the cab and I didn't bother putting them back in. Internally, the sides are bonded with the top, so I'm not expecting anything bad. A good Skeletal frame helps.
pfly
Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2827 |
Posted: 19 April 2013 at 7:38pm |
Are we talking about active crossovering versus passive crossovering or powered speakers versus unpowered speakers?
mini-mad
Joined: 13 July 2012 Location: london Status: Offline Points: 6861 |
Posted: 19 April 2013 at 7:47pm |
...neither, we're admiring Tony's handy work
Page <12345> |
