"NEW" PLANS CV earthquake sub-horn +infra upgrade! |
Page <12 |
kawmic
Joined: 15 April 2013 Location: denmark Status: Offline Points: 2 |
Posted: 15 April 2013 at 1:04pm |
jeg har 4 stk jbl 128h 12 " basser. synes de mangler noget i følsomhed(91db).
kunne godt tænke mig bedre følsomhed, the de kun er på 100watt vedvarende. Kunne et sådant hornsystem være godt til dem? måske med 2 eller flere enheder i? Venlig hilsen Michael kawmic@gmail.com
SvempaPrim
Joined: 24 February 2011 Location: Sweden Status: Offline Points: 74 |
Posted: 15 April 2013 at 1:29pm |
English please.
kawmic
Posted: 15 April 2013 at 1:40pm |
sorry. i was writing in danish, because i saw it was a danish poster.
ok. nevermind. here goes: I have 4 pieces jbl 128h 12 "woofers. seems they lack something in sensitivity (91dB). I'd like better sensitivity,because they are only 100watt. Could such a horn system be good for them? Maybe with 2 or more units? Sincerely, Michael |
joahed01
Joined: 15 October 2014 Location: SE Status: Offline Points: 1 |
Posted: 15 October 2014 at 10:13am |
Hi, i have an acousto-pro P18110A (specs: VAS 423, Qts 0,54, Qes 0,57, Qms 8,7, Fs 30, Re 6,2, Sens 98dB, Le 1,6 mH, Pmax 300, sd 1288cm2). I would like to make an L48 and use your new plans but i think this speaker needs more chamber space.....you have made 79l this speaker needs about 460l cab if i do an basreflex cab (i have that but i would like to try L48SE).
Is it possible, and what size must my internal enclosor be, and can i in the case that it will work use the unused spaces in your new plan (young croc). Best regards Jocke
tv00
Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
Posted: 15 October 2014 at 10:31am |
Hello there, sorry I didn't see all these posts until now.
If you're doing a new build I wouldn't recommend this design. I made a smaller rearchamber to control excursion, in this case we used mouth extensions (see thread elsewhere for details). But if you were to use these boxes without mouth extensions I would suggest making a port in front, no matter if it is the long or short version. The port and horn can be simmed in hornresp using the "combined response" function. This makes it a ported hybrid horn. This way you get two good things, cooling & low end extension. The port shoud be tuned to work just below the horn cutoff. Best freq is found in hornresp, go for a smooth response downwards, if you get a bump in the low end make the port tunning lower, if you get a dip, make it higher. I will suggest these mods only for people who already have the old boxes. @joahed01: In a brief look the driver doesn't look to suited for a horn, but perhaps a ported hybrid. If you're ever around Copenhagen you're welcome to come have a look |
Niclas Seifen
Posted: 30 March 2020 at 4:39pm |
@tv00 the pictures you posted, arent visible anymore, could you post them again or pm them to me?
VECTORDJ
Joined: 11 June 2006 Location: United States Status: Offline Points: 585 |
Posted: 02 April 2020 at 2:19pm |
A+ Can You post photos of the install??? VECTORSONICS
Page <12 |
