**new project** |
Teunos ![]() Old Croc ![]() ![]() Joined: 23 November 2008 Location: The Netherlands Status: Offline Points: 1793 |
![]() ![]() ![]() ![]() ![]() Posted: 14 May 2011 at 3:42pm |
So at the moment we have a lot of drivers sitting on the shelf doing nothing. Time to build an entirely new system. The mid-highs will be the last develeopment of the prototype mid tops i built (not the same as the prototypes). They go down to 200Hz. So from 35Hz upwards to 200Hz-preferably 240Hz for protection something has to be added. At the moment we have: 12 RCF L18P300 8 RCF L15P200AK 8 RCf L15S800 I was thinking, 4 horn loaded 18'' subs and 2-4 15'' on kick per side should do it for 1000-1500 venues. I'd preferably choose something stand alone on kick that i could use 4 per side for smaller gigs with small 12+1 tops. BR?? For sub, definitely horn loaded, but what kind of design, i have no idea yet. Perhaps WSX, Hog or tapped horn like andywave's miss piggy. building skills are top notch, they will be build by a friend who is a proffesional carpenter. Neither Amp power nor transport are problems. Would prefer some high subs to be able to get sub+kick up to at least 150cm for the tops. So just a quick assembly of a few sketchup models i put together over the past few years: These are hogs on sub and 15'' BR on kick, and my own mid-tops (missing tweeter cabinets) ![]() edit: The system will be used in large rooms and open fields. It has to play all sorts of music from jazz to hiphop, r&b, dance and trance, but never something like dubstep. Any suggestion is welcome! edit: Scoops i believe will be the answer. Edited by Teunos - 19 June 2011 at 5:29pm |
Best regards,
Teun. |
TechnoChef ![]() Registered User ![]() Joined: 23 April 2009 Location: Oxfordshire Status: Offline Points: 1109 |
Cubo 15 for an all round/kick bin?? My BPH kick design plays well without subs running a pd156 and would go up to 240 with a little mod to the front chamber, don't know how RCFs would compare. If you had more 18s, I'd say ES18s for kick/standalone.
Thinking you might need more than reflex to keep up with the pile of hogs though! IMO, of course! And nice sketching up by the way ![]() |
I think I'm in love with your mum.
djyves ![]() Young Croc ![]() ![]() Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
What about the CB-18X, it should go from about 35 hz up to at least 130hz.
And the RCF 18P300 works fine in it. Edited by djyves - 15 May 2011 at 6:57pm |
![]() ![]() ![]() Never mind. I don't believe bandpass are the way forward. It should be something hornloaded, just can't get my head around building inefficient bass cabs. Less power per driver on normal sound level and higher maximum SPL, so hornloaded is however the way forward. big batch of new RCF woofers on their way
![]() Edited by Teunos - 19 June 2011 at 5:28pm |
Best regards,
Teun. |
t.geessounds ![]() Young Croc ![]() ![]() Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
should it be the cbe-18???
I think Staiper won't mind me posting this: When i considered the CBE-18 i pm'ed staiper who sent me some very useful information Hello Teun, Despite those are in fact not real offset driver but S1-L12-S2 are used to simulate throat chamber and maintain real path length to the center of the horn. According to some builders real measurements this gives pretty good resemblance of real cabinet. (but all shoved tendency to have bit lower low corner freq. in reality than simulated) Other way you can simulate without "offset" with volume of cone and infront of cone as "throat chamber". Both ways you get pretty similar simulation graphs .. now only measuring the real model may show which is really closer. Yes symmetrical loading shows as really good in use :) .. of course trade-off is a bit more wood and cabinet weight and bit shorter horn than posible within same cabinet with single side folding. for HR I have for used as follows For CB-18 (standard version) S1=800 ; L12=21 S2=756 ; L23=188,5 S3=2050 ; L34=19 S4=3700 __________________ For CBe-18 (streetsounds version) S1=800 ; L12=21 S2=756 ; L23=188,5 S3=2050 ; L34=30 S4=5480 ___________________ For CBX-18 (full extended version*) S1=800 ; L12=21 S2=756 ; L23=208 S3=2600 ; L34=30 S4=6020 ____________________ Quick checked.. yes R.C.F. L18 P 300 sims very good in all versions of CB-18 :) Best wishes, Stipe -- Previous Private Message -- Hello Staiper, Recently i've had the idea of building a new sound system. The sub drivers will be .R.C.F. L18 P 300. I've made a 3d sketchup model of the CB-18E so i can easily transfer the measurements to a Hornresp sim. But even though i a lot of experience in running hornresp, i would like to know which measurements you used to sim the CB-18E so i can be sure i did it correctly. At first glance the R.C.F. L18 P 300 is a good contendor, but just to be sure i thought i should ask you. I love the idea of having a symmetrical horn as it reduces the chance of cone warping due to unequal loading pressure. I also use it in my kickbins and i like it. Big thanks. Greetings, Teun. This would be the end of the pm's O yeah, i underlined something i personally think is very important Edited by Teunos - 03 June 2011 at 4:37pm |
Best regards,
Teun. |
