New Push-Pull 15" |
Page <12345 10> |
| Author | ||
Sheggy
Joined: 23 May 2008 Location: London Status: Offline Points: 1984 |
Posted: 16 April 2012 at 7:58pm |
+1 I've had my eye on this thread to see what happens
overdrive
Joined: 13 July 2004 Location: Netherlands Status: Offline Points: 21 |
Posted: 16 April 2012 at 8:07pm |
I happen to have 2 homeless 15S330 drivers dying for a new housing, will you publish the drawings?
Edited by overdrive - 16 April 2012 at 8:08pm |
jeff generik
Joined: 25 November 2006 Location: Dartmouth,Devon Status: Offline Points: 219 |
Posted: 16 April 2012 at 8:22pm |
I have 4 fane 15 b 400's lying around do you think they would work in a design like this?
Tony Wilkes
Joined: 02 August 2004 Location: West Midlands Status: Offline Points: 4835 |
Posted: 17 April 2012 at 3:39am |
p.m. me your Email and I will send you the drawing. It will be as a dxf so you will need to load it into a CAD programme like the free Draftsight* to get dimensions but all the info you need is on there. I don't have time at the moment to dimension it up. Tony * http://www.3ds.com/products/draftsight/overview/ |
Tony Wilkes
Posted: 17 April 2012 at 3:42am |
Did a 12" version, but that went commercial ![]() Tony |
Chaps
Joined: 19 October 2010 Location: Danmark Status: Offline Points: 58 |
Posted: 17 April 2012 at 5:31am |
Oh, i see ![]() It's because I now have 4 KappaLite 3015LF in JBell SS15 tapped horns, but i'm not satisfied with the single-box output if you're doing a job with one on each side of the stage. I can centerstack two for a lot better performance, but it isn't that practical for all type og gigs. So i was looking into trying another kind of box for them. Allways been a fan of simple reflex because of the sound quality and the fact that the cabs can be rather compact. And they work just fine on there own. Was thinking about a compact cab with a V-baffle similar to this: http://www.novacoustic.com/english/VS215SUB01.jpg But I then started to read more about PPSL enclosures and the benefits from push-pull and thought it sounded interesting, as I just see it as a kind of improved reflex design. If you are familiar with the 3015LF, do you think it is possible to do something like your design/PPSL with good results? I'm really not into hornsresp, akabak etc., but maybe i should take my time to learn it?
overdrive
Posted: 17 April 2012 at 11:42am |
DXF no problem, but the PM button...where is it?!
Tony Wilkes
Posted: 17 April 2012 at 11:56am |
You need 2 more post's, 10 needed to PM anyone
overdrive
Posted: 17 April 2012 at 11:59am |
Well that...
overdrive
..shouldn't be..
overdrive
Posted: 17 April 2012 at 12:00pm |
..(indeed Tony
)Edited by overdrive - 17 April 2012 at 12:04pm |
Tony Wilkes
a problem?
Page <12345 10> |
