New Stasys 'Phil' |
Post Reply | Page <12345> |
Louder than loud
Old Croc Joined: 13 May 2010 Location: Guildford Status: Offline Points: 2377 |
Thanks(1)
^ JBL SRX725 ^ Cant wait to hear these tho and am sure that there sound as good as they look :) maybe a little demo nye chris ;)
csg
well, the rate im going, i might be quicker just asking them for everything in the warehouse.
Louder than loud
You brought MORE !! ?
jazomir
Old Croc Joined: 20 November 2006 Location: Sunderland UK Status: Offline Points: 1710 |
In that case why didn't they call it the 'VOID Tea Party Special'?
cilla.scope
Old Croc Legs all the way to her bottom.... Joined: 02 October 2009 Status: Offline Points: 2954 |
yes, but ages ago, a 2x12" +1" was about the right sort of SPL for a monitor, or a small pub gig ... nowadays with Neo drivers, you can get crowd pleasing levels out of the neo equipped versions ... a box that size could take 2kw + with the right drivers ... the world is changing and Neo drivers mean you cannot assume what was previously a "monitor sized box" has monitor performance any more ... |
My girlfriend thinks I'm a stalker.
Well, she's not exactly my girlfriend yet ... |
Plaguesguitarist
Old Croc Joined: 30 April 2009 Location: Lincoln, Earth Status: Offline Points: 2238 |
Drum fill - drum Phil?
Phil - Fill?
Possibly why the name. Regularly use a 2x12 +1.5" as main mid tops in a pa. 300w:16ohms. Loud as hell. HIQ audio specials. Very efficient on Ass subs.
To steal MY sharpie. |
ceharden
My main system is a 2x12"+1.4 and I have single 15"+1.4" wedges/multipurpose boxes. But I wouldn't want to use a 2x15" for FOH duties without a dedicated midrange.
iand4403
Registered User Joined: 05 February 2008 Location: Leeds Status: Offline Points: 626 |
Off topic: What components do you use in your 15" + 1.4" boxes? |
toastyghost
Surely that depends on the properties of the 15" driver though? |
ceharden
In answer to the first question: B&C 15NW76 with 18Sound ND1424BT on XR1464 flare. Passive crossover based on the 18Sound 15" mid-top reference design.
One of the problems with using a 2x15" or even 2x12" is the distance between the sound sources, particularly the lower 15" and the horn. In my 2x12" boxes I've squashed everything up as much as possible but it's still not ideal. The 15" driver choice for a 2x15"+1.4/2" is a tricky one. For such a large box you really want to make it full range to be useful, however that requires a heavier 15" which won't have as nice a midrange. If you go with a light 15" and sacrifice the low end, you might as well use 12" drivers and make the box much smaller. The EV/Shuttlesound Motivators tried to get around this by using two different 15" drivers, a heavy coned Gauss to do predominantly the lower end and a much lighter EV Proline driver with a better midrange. However the Proline was so much more efficient, the Gauss didn't really do that much in comparison. |
Centauri
Old Croc Joined: 29 November 2004 Location: Newcastle Aus Status: Offline Points: 1792 |
A 2x *any size* plus horn box, where the horn isn't between the two woofers, should be running a 2.5 way crossover so that only the driver closest to the horn is operating at the horn crossover point...
levyte357-
Apparently Phil uses the same horn as above. Anyone have Void part number, or know where to locate these? |
