  New Posts New Posts RSS Feed - New sub
New sub
 Post Reply Post Reply Page  <1234 8>
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2009 at 2:40pm
Cool, how come the wheels arent on the back?
MusicXtra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MusicXtra Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2009 at 3:55pm
The wheels on the picture are from a dolly, this is only a prototype.
audioalliance View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioalliance Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2009 at 2:32pm
very nice build.. But what's the weight like though?
http://www.myspace.com/audioalliance
music is our mission
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2009 at 2:56pm
Heey music, do you have any plots for this new cab? Measured response or just the plotted simulation(hornresp, akabak or whatever you used) is both fine.
Best regards,
Teun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MusicXtra Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2009 at 2:58pm
This prototype is heavyer than a tankShockedbut this is made from MDF.
The birch plywood version is much lighter but tanks to all the bracing inside it's still around 90kg.
everdark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everdark Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2009 at 8:48pm
Xtra you doing great things as i've noticed.
Try Neo subs for your sub, such as b&c or ciare.
music is the only language I really know
Post Options Post Options   Thanks (0) Thanks(0)   Quote MusicXtra Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2009 at 8:12pm
Tnx for the tip but I allready have 8 Beyma 18 G550's.
The only advantage of Neodynium is the weight of the driver and for subs it is not a very important issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote everdark Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2009 at 8:37pm
ok i understand.
btw, how far do your LA play?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MusicXtra Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2009 at 9:45pm
ok i understand.
What do you mean with far, the throw or if it's finished?
The throw is about 30/40 meters.
I'm waiting for anodising the rigging hardware for the last 6 cabinets.
Than I have 12 cabinets complete.Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote everdark Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2009 at 10:20pm
yes i meant throw.
The point that keeping me from building tiny array is that they almost useless about midbass frequencies. But i don't wanna build a giant hornloaded ones, so how low do yours play?
wafflesomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2009 at 10:25pm
Sb1000?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MusicXtra Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2009 at 10:38pm
yes i meant throw.
The line-array is usuable from 100 Hz.
But, for the best result, espessialy for dance events the system needs a kick-bin from 80-150 Hz.
The range 80-150Hz is a problem for the most small line-array's because the length of the array is to short for this frequentie.
