  New Posts New Posts RSS Feed - New Sub-Horn plan?
New Sub-Horn plan?
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Topic: New Sub-Horn plan?
    Posted: 19 March 2006 at 7:29am
Ive been messing about on paint to come up with a new 18" Folded horn to be used for true sub bass (like the lab sub) as apposed to the rib breaking kick of an 1850 horn say.
I have tried to achieve this by making the horn length quite long (about 3m) . Im quite a novice in this field so any critisisms are more than welcome so i can modify it etc. also would an 18" driver be suitable for such a large horn length?
heres the general layout:
Jay Lawless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2006 at 12:10pm
a large horn length just extends the lower f3 a little more. more horn path = lower frequency, but a bad part i see here is that you'r horn mouth is much too small. extend the front by about 15.25cm and add a bit more to the horn mouth to bring out the kick *SPL*. also i would sugjest using the rearchamber of a 1850horn for refference for you'r rearchamber. the rearchamber of a 1850horn is just about 70L, base you'r design off of that and the drivers ment for the 1850horn to get you started.
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2006 at 1:12pm
how about this.... bigger horn mouth.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2006 at 3:44pm
Um, it's getting a bit big!
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2006 at 4:08pm
isnt that nearly as big as a lab?
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2006 at 4:24pm
Your horn path appears to tighten and expand in different sections too
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2006 at 5:11pm
yeh thats what i thought.
its just a very first idea tho. i did it on paint in 5 minutes
back to the 'drawing board'
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2006 at 11:56pm
try something like this, though maybe not as many lines but something simular. try a HxD of 90.25cm high and 90.25cm deep. and also try a width of about 76.2-76.25cm, that should give you plenty of room.
Edited by NeverWinter - 19 March 2006 at 11:57pm
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 2:56am
I see a whole lot of wasted space in there...
Ex Nexus_3
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 3:40am
if thats your design! i wouldnt use the word sub!!
and the mouths to small.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 3:42am
exactly why i said not to really go by those folds.
personaly i think it's a little much... but hey, who ever said you couldn't try you know...
Jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbo Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 11:44am
Do your simulations, decided on your compromises and when your satisfied, build a prototype.  This being said from someone who is in this as a hobbie.  Building them is more than half the fun.  If size doesn't matter (depends on who you talk to), why not?
If you have access to AutoCAD, Graeme has a very cool program for doing horn foldings on his sight.
Jim
