  New Posts New Posts RSS Feed - New Sub-Horn plan?
New Sub-Horn plan?
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 2:47pm
Originally posted by ceharden ceharden wrote:
Um, it's getting a bit big!
Maybe we should spec required freq resp, and then arrive at the best way of acheiving it.
I personally think a WSX would be a good design starting point,
SNIP
Did have plan for WSX with internal dimensions here, but edited it
out so speakerplans.com doesn't get slapped for
encouraging copyright theft.. WSX internal here
SNIP
but with simpler driver mounting, access plate heatsinking, sensible 1850 compatible rear horn chamber, resulting in a final design with 8ft+ horn length, that does 38hz to 150 "flat", without over excursing driver. I wouldn't mind carting 4 of these around if I knew I was guaranteed 38hz, without ridiculous eq or blowing a few xmechs/xmax's every gig.
Edited by levyte357 - 20 March 2006 at 3:36pm
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 3:46pm
@norty303 - as regards to your comment about the horn getting largaer and then smaller, i have made some adjustments. added about 250-300 mm to the height and changed the folds abit
Jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbo Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 5:05pm
Have you modeled this on Hornresp yet?  Need to make sure your heading in the right direction before working on the folds.
If you have, I could have a go at the folds in AutoCAD for you.
Jim
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 5:37pm
Jim
no. i am a complete novice and just doing this as a bit of fun.
what would be involved in modelling it on horn response? if you could do the auto cad and what have you, i would be very grateful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbo Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2006 at 11:20am
Hornresp is pretty simple once you understand the inputs.  Search the forum on it and you'll come accross a lot of good info (including where to get it).
Jim
Jay Lawless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2006 at 4:47pm
Jim
you'l never know if you'r horn is good at all intill you input it into hornresp. intill then you, nor any of us will be able to tell you that it's worth trying out. the drawing is looking better, but theres no inputs to go by. once you learn hornresp it should be easy to help you out after that. plus by supplieing atleast rough measures *incase you want to keep the design for copyright reasons* it will help others try to tweak the design slightly to help increase or decrease certain aspects of the design.
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
