  New Posts New Posts RSS Feed - New System
New System
dickscode View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dickscode Quote  Post ReplyReply Direct Link To This Post Topic: New System
    Posted: 10 September 2007 at 7:19pm
Thinking of building a system using 2 or 3 Punishers and 1 Porn Horm mk2 per stack. Generally it will be live music with some '80's dance!
Anybody have an opinion whether I would be stretching the crossover points of them both or if they would be ok, don't really want to add another low mid cabinet.
Thanks
rinse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rinse Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2007 at 12:52am
I don't think the Porn Horn goes nearly low enough.  You could try running the Punishers that high but most claim it doesn't sound that good.
A shame really but some HD15s would do the trick and let the Punishers concentrate on the lower frequencies...
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2007 at 11:01am
It all depends on what you load the punishers with.
I've heard that the ciare doesn't like it up high
I believe  the porn horn goes down to 140?
Discode, is it near-field sound your looking for? porn horns and punishers are really outside Joby's, well the Porn horn I would say is, looking at the depth and dispersion.
The old gals at the back wont be able to chat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2007 at 11:36am
I've given ours a go at about 130Hz and they seemed okay, the response is certainly loud enough.
Sibulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sibulus Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2007 at 2:02pm
Cab resonance though? We go up to 100Hz, max. Keep it doing what it does best.
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2007 at 11:18pm
Got 2 stacks of 3 up to 140Hz in a big marquee, sounded fine. Think we even tried 160Hz and it wasn't bad but 140 did sound cleaner.
Inside a hall I just found that 140hz rattled the sh*t out of everything, 112Hz worked well for me there.
Edited by odc04r - 12 September 2007 at 11:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sibulus Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2007 at 7:56pm
What do you run ontop of them? We use X-tros.
