Newbie Essential Reading |
Post Reply | Page <1 567 |
Shimad
Registered User Joined: 19 August 2014 Status: Offline Points: 16 |
Whole lot of essential info here.. Thanks!
jackath
Registered User Joined: 03 December 2018 Status: Offline Points: 17 |
Very useful - thanks :)
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Online Points: 1174 |
Thoughts on line arrays - Updated Link:
http://www.burton-manor.co.uk/index.php/legacy/1-thoughts-and-ideas-behind-the-design-of-line-arrays
Edited by APW - 03 December 2018 at 3:58pm |
toastyghost
The original VDOSC manual from the same era ca. 2005 is also a required reading. It’s a few hundred pages long and has lots of theory and diagrams. |
John C
Registered User Joined: 07 September 2020 Location: UK Status: Offline Points: 10 |
What speaker design software would you recommend? I have the Eminence designer but it seems a bit out of date and not very user friendly. Any advice would be very welcome
djeddie
WinISD HornResp (Just Google those two names) There's loads of threads on this site that will explain how to use them. WinISD is like the Eminence one (which is actually Bass Box Pro, but with just Eminence drivers in it... and is, as you say, years old. I had the Emi one running on a Windows 98 machine). HornResp is very much more in depth. As the name suggests it's mainly for horn design, but can be used to model many different styles of cab. Edit: Oh yeh... and they're both free of charge!
Edited by djeddie - 07 September 2020 at 5:48pm |
teeth
Young Croc Joined: 05 July 2021 Status: Offline Points: 566 |
just a heads up, the links to "The EV PA Bible!" sadly don't work |
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 886 |
Amazing what you can find using an interweb search engine |
It's a difficult choice, would you rather have:
A: A vegan son. B: An OnlyFans daughter |
teeth
course bruv, just wanted to let the OP know some links were dead after they spent a bit of time making that first post :)
mia154
New Member Joined: 08 November 2021 Status: Offline Points: 1 |
Thanks for these informations!
toastyghost
Thanks(2)
An amazing resource here from the AES. Essentially a free pro audio dictionary, keep this bookmarked and check it whenever you’re stuck:
https://www.aes.org/par/ As part of that is a fairly comprehensive list of books on any audio-related topic, with a comment or mini-review: https://www.aes.org/par/book/ A few of these are 100% essential for any audio engineer: Beranek - Acoustics Olson - Acoustical Engineering (even if you don't understand most of these first two now, you'll be thankful it's on hand later in life) Horowitz & Hill - The Art of Electronics (essential) Davis & Patronis - Sound System Engineering (the most practical book on system design and deployment) McCarthy - Sound System Design & Optimisation (green Bible, tons of graphics, charts and references. Covers design, deployment and measurement. Consitent results and lots of answers to common questions) Borwick - Loudspeaker and Headphone Handbook (lots of info on how speakers really work) Colloms - High Performance Loudspeakers (see above. Studio focused but with good reason, lessons apply to all speakers aimed at high quality output) Howard & Angus - Acoustics And Psychoacoustics (not as much maths as you'd think... really fun to read, will help you realise and decide what we actually hear) Eargle - Handbook of Recording Engineering (studio focused but will help you mix bands better) I will always recommend spending £40-50 on a physical copy off eBay or from a second-hand bookstore - put them on your Christmas and birthday lists! - having books on a topic communicates to yourself and others that you are that person. This sort of thing is under valued, but it makes a big difference. Even just seeing the spine on the shelf or having it on your desk. Read a chapter a weekend, or just check it BEFORE GOOGLE when you have a question. However, you can find digital copies online if you're familiar with the library named after the creation story in the Bible... |
