Newbie set-up help |
djgorey
Young Croc Joined: 29 December 2007 Location: S. Wales Status: Offline Points: 1306 |
Posted: 07 July 2019 at 9:22am |
Hi all
Looking for some help in setting up my dcx. It’s a mobile disco rig so goes mixer -> dcx -> amps (1 bass, 1 mid-hi). My amps are quite a bit bigger than my speakers so I’ve set up the limiters to protect them. The limit lights on the dcx flash when the master out on my mixer is at about 75%. What I’d prefer is to have the master out on my mixer at 100%. The limit value is different for bass and tops. Is the way to do this to reduce the input gain on the dcx to get it most of the way and then use the output gains to fine tune?
Gaffa tape is like the force in Star Wars - there's a dark side and a light side and it holds the universe together
Conanski
What is the typical master signal level at on your mixer with the control at 75%? If it is at +8dB or more you're already out of headroom on the mixer.
djgorey
It’s an Ecler Nuo 4.0 so there’s no output metering, just mix levels pre-master out. At 100% it’s 0dBV
Conanski
Ok the mixer has relatively low output then, you're probably only getting the first 2-3 input LEDs lit up on the DCX now anyway? In that case your plan is good crank the main out to max and adjust the levels and limiting in the DCX, should work fine.
djgorey
Cool. Thanks and yes, I’m only just lighting up the input meters on the berry at the moment.
ceharden
It's pretty normal not to see much on the input metering on a DCX. The meters are relative to full scale which is something like +22dBu (18dB above +4dBu nominal).
If you want to run your mixer and the input of the DCX hotter, just turn down the input gain control on the DCX to -6dB or less.
djgorey
So I’ve set the gains and limiter as I would want them and now I can turn my mixer up full and the limit lights don’t flash so all good.
However, I then tried turning the input gain up on the mixer channel to try to get the limiters to kick in - I want to see what happens so if it ever happens on a gig, I’m ready. I didn’t have my speakers connected. The limit lights on the berry came on as I would expect, but it didn’t seem to cut any signal to the amps; the amps were still flashing away. I’ve set a 4s release time so in my head, I’d expect the music to drop out for 4s once the limiter is hit? Have I misunderstood how it works or am I missing something in how I’ve set it up?
JBK
Registered User Joined: 03 March 2016 Location: Besançon Status: Offline Points: 262 |
A limiter do not cut the signal but rather stops it from increasing further when it's higher than the threshold, so when the limiter comes in action the signal still pass by but is reduced during the release time (4s in your example) You got to know that the dcx only have a peak limiter which is not the best way to limit a system. To avoid speaker damage, you'll need a RMS limiter. Peak limiting can do more bad than good if not controlled, ie if a daft DJ turns everything in the red, the dcx will be in constant limiting and the signal that will pass will look like a square wave (high RMS value but no peaks), not good at all for the amps and speaker, expect to cook some coils. The dcx will limit the peaks but will not activate if the average power of the signal is too high (without peaks) If I'm talking chinese I'll suggest more reading and learning on the subject till you feel confident. Look up for rms versus peak limiting, crest factor. This subject is complex, but already talked about dozens and dozens of times, here and on other forums.
djgorey
Brill. Thanks for the tip.
After I posted it, I kind of worked it out. I’m the only person going to be using my rig so the limiters are for my benefit. If I see them flash, I turn down my mixer until they go away!
