  New Posts New Posts RSS Feed - Newly aquired kit
Newly aquired kit
concept-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2019 at 6:52pm
The 12lx60v2 is a brilliant driver, I use a lot of them in our tapped horns, some drivers do have an advantage in certain areas, however are they as physically strong, the beyma is a tank, we have abused the crap out of them and never had a problem with the cone, some will not be as physically strong, i would go with the driver the performs well and has proven itself in lots of tapped horns, just my thoughts.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2019 at 7:02pm
Originally posted by APW APW wrote:
Please don't get me wrong, I'm not dissing the MTH-30.... both the Tham and the MTH are good proven designs and have very good output considering their small size.
Not problem.. i follow you :) And agree with you..
What tapped horns are they? Just curious :)
I know the LX series from the old series. 18LX60 was i beast. And if they have keept to the recipe on the v2 series, maybe improved it, it should take a beating!
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2019 at 7:41pm
They are our own design, closer to the tham than yours and they give the driver a slightly harder time, we are currently working on a new variant that will go lower at the expense of a bit of spl and we are using the 12lx60v2 again, they really are very good in this situation, there is a driver on Thomann called the box 12 280 8w it's  about €50, a few people have said it's very good in the mth30, I've not simmed it in anything so you should give it a look, you never know Smile
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2019 at 7:49pm
I do not like The Box products. You get a great bang-for-the-buck, but it ends there.
Many do praise them, but i dont want to go cheap-ass.. I want the best possible performance :)
Not the best price-to-performance ratio :D
Quality do have a cost.
Sounds interesting. You got any photos? Not that i want to copy anything. Just want see what you got. Large visible magnets are porn haha :D
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2019 at 3:48pm
The Beyma 12LX60v2 is the driver the Tham-12 was developed with, and other than the MTH30 having a dB or so extra output the response for the two enclosures looks extremely similar when using this driver.
This is interesting considering the MTH is over 25% larger than the Tham they both have almost exactly the same output.
Think about how speaker efficiency increases when you go from a single to a double cab with the same driver - you'd expect 3dB more output for that increase, right.
Now work out how many consecutive increases of 25% it takes to equal a doubling.
What that adds up to is that one extra dB of efficiency for a 25% bigger cab is exactly what we'd expect, all else being equal. Wink
APW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APW Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2019 at 4:23pm
The extra dB is not what I found interesting, both the MTH and Tham are tapped horns and about 100ish dB/watt is what I’d expect a typical small/compact TH to produce, The Tham 15 is almost twice the size of its little brother and still only produces about 100dB/watt.
What I was expecting is due to the increased volume of the MTH was for the F3 to be slightly lower than the Tham 12 as I expected it to have a longer horn path… this isn’t what the sims sugest, the f3 is almost exactly the same.
I haven’t worked out the lengths of the horn yet on these two cabinets so cannot say for sure, but I’d imagen the horn length to be similar.
Edited by APW - 17 June 2019 at 4:37pm
