Newly aquired kit |
Post Reply | Page <12 |
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1292 |
The 12lx60v2 is a brilliant driver, I use a lot of them in our tapped horns, some drivers do have an advantage in certain areas, however are they as physically strong, the beyma is a tank, we have abused the crap out of them and never had a problem with the cone, some will not be as physically strong, i would go with the driver the performs well and has proven itself in lots of tapped horns, just my thoughts.
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 813 |
Not problem.. i follow you :) And agree with you..
What tapped horns are they? Just curious :) I know the LX series from the old series. 18LX60 was i beast. And if they have keept to the recipe on the v2 series, maybe improved it, it should take a beating! |
concept-10
They are our own design, closer to the tham than yours and they give the driver a slightly harder time, we are currently working on a new variant that will go lower at the expense of a bit of spl and we are using the 12lx60v2 again, they really are very good in this situation, there is a driver on Thomann called the box 12 280 8w it's about €50, a few people have said it's very good in the mth30, I've not simmed it in anything so you should give it a look, you never know
FOO
I do not like The Box products. You get a great bang-for-the-buck, but it ends there. Many do praise them, but i dont want to go cheap-ass.. I want the best possible performance :) Not the best price-to-performance ratio :D Quality do have a cost. Sounds interesting. You got any photos? Not that i want to copy anything. Just want see what you got. Large visible magnets are porn haha :D |
DMorison
Old Croc Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1647 |
Think about how speaker efficiency increases when you go from a single to a double cab with the same driver - you'd expect 3dB more output for that increase, right. Now work out how many consecutive increases of 25% it takes to equal a doubling. What that adds up to is that one extra dB of efficiency for a 25% bigger cab is exactly what we'd expect, all else being equal.
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1173 |
The extra dB is not what I found interesting, both the MTH
and Tham are tapped horns and about 100ish dB/watt is what I’d expect a typical small/compact
TH to produce, The Tham 15 is almost twice the size of its little brother and
still only produces about 100dB/watt.
What I was expecting is due to the increased volume of the MTH was for the F3 to be slightly lower than the Tham 12 as I expected it to have a longer horn path… this isn’t what the sims sugest, the f3 is almost exactly the same. I haven’t worked out the lengths of the horn yet on these two cabinets so cannot say for sure, but I’d imagen the horn length to be similar. Edited by APW - 17 June 2019 at 4:37pm |
