Newly built 186 |
Page <12345 6> |
| Author | ||
streetsounds
Joined: 12 July 2008 Location: Santa Rita Status: Offline Points: 301 |
Posted: 11 February 2009 at 4:17pm |
What about spec of this driver, is it also similar with the V18 1000? How does it sounds like Xmax? I think Im beginning to some interest on it.
Edited by streetsounds - 11 February 2009 at 4:21pm |
Bass matters...
Xmax extreme
Joined: 23 May 2006 Location: Pilipinas Status: Offline Points: 308 |
Posted: 11 February 2009 at 4:37pm |
Not sure whether this uses a kurt muller cone adam, but for the price of 200USD,I can say that it has great build quality.
Maximum Excursion
Don't criticize your own competition, it looks like a publicity of your own commercial products. |
Xmax extreme
Posted: 11 February 2009 at 4:47pm |
streets here is the specs..... Fs = 28 Hz Qts = 0.2 Qms = 1.325 Qes = 0.236 Vas = 315 liters BL = 31.2 Tm no = 2.825 % Cms = 123.7 µm/N Mms = 261.2 g Rms = 34.68 kg/s Sd = 1339 sq.cm Re = 5 ohms Le = 0.68 mH Z = 6 ohms no = 2.825 % 1-W SPL = 96.66 dB 2.83-V SPL = 98.7 dB 8 mm xmax 5 inches voice coil Dual spider It's worth a try,,,,, |
Maximum Excursion
adambomb
Joined: 10 April 2006 Location: United Kingdom Status: Offline Points: 3220 |
Posted: 11 February 2009 at 5:09pm |
The specs are little down on the real deal (PD1850).. but still... (if the pound was a bit stronger) they would be a bargain... (as it is with the pound - dollar I will stick with the real deal).
Insomnia
Joined: 06 September 2005 Status: Offline Points: 1721 |
Posted: 11 February 2009 at 5:37pm |
Well done guys - i admire your passion-
a great build-
keep it up.
Insomnia Sound Systems - Custom speaker cabinets built to order.
Xmax extreme
Posted: 11 February 2009 at 5:39pm |
LoL, spot on that adam,,, also noticed that.
Maximum Excursion
heinrich
Joined: 21 February 2007 Location: Calindagan Status: Offline Points: 280 |
Posted: 12 February 2009 at 4:08am |
heheheheheh guapo ka pala pards.hehehheheheactually never been abroad ....... not like Xmax.........hehehehhe Xmax is one furtunate enough to sneak in some chinese factories.......hehehehehhhe ![]() Xmax: do that picture means it's a NEUSCH PD1850 by T&T ? 5" voice coil.......flat aluminum cord....
.....power is nothing without control....
Xmax extreme
Posted: 12 February 2009 at 4:28am |
LOL!.... yeah lucky enough considering it was an all expense trip sponsored by the company....
The Neusch PD1850 is the first edition bai... The PD1850B is the optimized edition..... B for Bass horn loading.... Right on that, this come with 5 inches flat aluminum wire. |
Maximum Excursion
Rog
Rogers Archive Posts Joined: 23 March 2010 Status: Offline Points: 2166 |
Posted: 12 February 2009 at 4:49am |
Yep I know T&T, they are Shanghi based. Not a bad product, but i've always managed to blow all there stuff up. I'm not sure the coils are up to much.
Void sources the chassis and magnet for the V18-1000 from China, they are pretty generic parts and I know of at least another 4 companies here using the same chassis and magnet. But thats where the similarities end. We wind our own coils so I know its good stuff and there is no way they can get a Muller cone into China and use it in a product with a street price of 150 to 200 USD. The glues used will probably be crap as I've never seen a Chinese glue that can hold anything together for more that 10 mins. Again to import western quality glue would bring the cost up a lot. The way the lead in wires are designed and fabricated also has a lot to do with reliabilty too. I'm not sure that some 18 year old on coral draw really knows whats needed when it come to designing super reliable lead in wires.
So no, not a copy, its just using a lot of the same parts as I do for the V18-1000. Its the coil, cone and suspension that make a good woofer and I know they are not using the same as me as they are not buying parts from me.
heinrich
Posted: 12 February 2009 at 5:01am |
nice hearing from you Roger......
so how much will it cost us if for example we will buy these Voids (v18-1000) from you then in USD please.... from your kingdom to our philippine islands |
Rog
Posted: 12 February 2009 at 5:46am |
This may sound strange, but I don't know any of the prices of Void stuff and I don't want to.
I'm not a salesman and I can't design if I know how much things cost. I'm not prepared to build or design to a cost, so its better than I never know how much it all costs.
I think you will have to ask a Void distributer how much the V18-1000 costs.
Best wishes,
Rog.
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 12 February 2009 at 1:10pm |
does the v1000 use a Kurt muller cone, I thought at one point you said the V1200 did but not the V1000?
Page <12345 6> |
