Nexo PS15 MK1 problem |
Post Reply | Page <12 |
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2544 |
Right. And that means that in order to get 2 speakers working in passive mode and in stereo from a 2 ch amp you need to rewire the speakon cables, 1+1- at the amp end and 2+2- at the speaker end.
Digbethdave
Registered User Joined: 16 November 2018 Status: Offline Points: 406 |
Basically. The LS subs are on pin 1, so LS with a ps on top, you only need a 4 core cable and a link. The connector on the internal crossover, should have a link on it in passive mode. They are all pretty old now, I've had to repair dry joints on the crossovers a fair bit last year (out of a stock of 5). Also be aware that the track on the pcb will probably be lifting.
BradRWills
Young Croc Joined: 11 November 2010 Location: Reading Status: Offline Points: 504 |
The easiest way to do this in my experience is to use a patch panel - and wire the sub into 1+ / 1- and the tops into 2+/2-.
Then you just run a single 4 core to each side, and a fly cable between the sub and the top. Works for me! It takes a while to get used to the odd wiring config on them, but it does, when you think about it, make a lot of sense! Or... they’re broken - in which case, send me the cabs, because mine look like they’ve served in several war zones at the moment 😂
Edited by BradRWills - 12 December 2020 at 2:00am |
