Nexo vs Tham15 test! |
Post Reply | Page 12> |
LjudLahger
Young Croc Joined: 31 July 2008 Location: Sweden Status: Offline Points: 838 |
Posted: 24 July 2015 at 11:21pm |
Had some fun a cuple of weeks ago!
Test was done in a big warehouse, DEQ2496, ECM8000 on some foam on the floor 1,5m from speaker. Do not take the spl/m/w seriously. Room did a lot to the plot but you can see how much sensitivity diff between cabs :-) Impedance has been nom and cabs with x2 drivers plays 3dB higher. No filter, DSP or any Nexo hocuspocus. Cabs tested: Tham15, PD.154 loaded Nexo LS500 Nexo LS1200 Nexo RS.15-C Nexo Alpha S2 Edited by LjudLahger - 24 July 2015 at 11:24pm |
LjudLahger
Edited by LjudLahger - 24 July 2015 at 11:25pm |
csg
if you did not use the nexo processing, then the above is a bit meaningless in my opinion - the processor i an integral part of the system, the boxes are designed and tuned to work along with the processor.
whether or not that is a good thing is another subject altogether...
LjudLahger
True, but I was curious of the cab itself, and from a DSP view "how much are ok to eq" and what starting point they got, if you know what I mean.
csg
fair enough, but as i said, nexo really needs the processing.
GEB
Old Croc Joined: 13 November 2009 Location: East Midlands Status: Offline Points: 1993 |
Does the Nexo processor effect the sensitivity then? As I got the impression the ccomparison was done to illustrate the differing sensitivity between the cabs and not How flat the plot looks.
Earplug
I don´t know about the Nexo bass bins above, but I do know that the PS10/15 sound like shite without their processor.
It is interesting to see how well the Tham 15 does against the 'raw' Nexo cabs, but really you have to agree with csg - without the processing, it´s all a bit meaningless. |
mini-mad
what sort of processing we talkin about here..... could you, just for the sake of a test and a quick ten mins, apply the SAME processing to the tham and see how she sounds?
i understand they are different boxes with different driver and all that shizzle but ya'know, as you have the boxes out anyway............. |
LjudLahger
Thats an idea! This was done a cuple of weeks ago but maybe we could do it again! And yes its a shame I did not test with processing but it was the cabs it self i was after. So if there be a next time I will try to get all meassured. Anyway, I thought this would be interesting for some people because you dont see this everyday And fewer people wants to share here anymore :-) |
njw
Old Croc Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2572 |
^^This, or run the Nexo's with the controller and the thams with whatever settings they need to sing and then see what the result is.
mini-mad
^^^^^ oooor.... do all of them!
ceharden
If you didn't know, the reason for this is that the passive crossover in the PS10/15 is not designed to give a flat response and doesn't contain any of the attenuation required for the HF because this just wastes power dissipating it in resistors in an L-Pad. Instead the attenuation is done in the controller. It's very hard to recreate what the controller does just using EQ.
