Nice one PD... :) |
(SoundcreationaudiO)
Registered User Joined: 09 October 2007 Location: Wales Status: Offline Points: 306 |
Posted: 29 November 2008 at 7:27pm |
i had a few pd184 drivers fall apart on me when used in pretty normal standard conditions, the cone just separated away from the former simply down to lack of adhesive as far as i can see.. some uncaring employee i imagine..
but!, had a word with the the pd bunch, and 3 new drivers turned up on friday, improved glueing by the looks of it, a much larger bead of adhesive present at the base of the cone.
so, nice one! first class service from PD fair play.. and nice to deal with as always..
the smf
Registered User Joined: 08 May 2008 Location: United Kingdom Status: Offline Points: 761 |
any idea what the manufactur date on those faulty ones were?
just bought 3 from blue aran n hope they dont have the same problem
Existenze Records - http://www.chemical-records.co.uk/sc/downloadstore/release/6625
jbl_man
This appears to be a common fault....look at this thread.
theyd be the new replacements smf, so no wories..
Edited by (SoundcreationaudiO) - 29 November 2008 at 7:55pm |
the smf
hope so, 2 are from august and the other was september of this year
u could make sure, and use some 2 pack epoxy.. run a bead around the base of cone/coil former to bond the 2 together even more?
I think the date on the stickers are from a batch from may this year.
the smf
dont say that, the odd pd 184 i purchased from davey t at the same time as buying the usb prototype is from may 2008
altho i can see a nice glue residue around the yellow suspension part, would it be safe to assume that this might be one of the better ones???
mmmm, go buy some araldite... just in case.. wont take you 5 min to run a bead around .... above the suspension and over the base of the cone..
