Nightfire Scoop / Rear Loaded Horn |
Tekasis
Old Croc Joined: 03 July 2006 Status: Offline Points: 6492 |
Posted: 14 October 2006 at 10:02pm |
Anybody seen these scoops about or heard / built them ?
They sound interesting.
Nightfire says:
20" Scoop / Rear Loaded Horn - Are your 18" scoops not loud enough? The PR20120 in this relatively easy to build scoop design will BLOW YOU AWAY! 500W AES, 1000W Continuous, very low power compression and unbelievable sensitivity gives you MORE BASS from a cabinet no bigger than a 'standard' 18" scoop.
The 20120 really is a unique bass driver due to the way it behaves under power, giving you a 'truer' sub bass response, and insane SPLs! You won't be dissapointed...
tb_mike
Old Croc Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
I think bassmaxx is better/larger. It has much larger mouth area and much less wastage of space |
mykey
looking at the drawing, it wouldn't work that well Edited by mykey - 24 February 2007 at 5:59pm |
SmokeyJoe
Young Croc Joined: 22 August 2006 Location: United Kingdom Status: Offline Points: 534 |
That design wastes loads of space. Where the "scoop" bit is (at 45deg).
I dont like it - sticking to microscoops... |
Static Age
Old Croc Joined: 14 November 2005 Location: Oxfordshire Status: Offline Points: 1652 |
all scoop designs have that huge space where the scoop part is.
Tekasis
SmokeyJoe, What are the Microscoops like ?
What are they loaded with ?
I'm thinking of a couple myself. I see the design are for 15'' drivers, do you know what they would be like if I keep the same dimensions but cut the hole to take an 18'' driver ?
Thinking of putting either a PD1850, PD186 or Void V-18 1000 in them.
Cheers.
jethrocker
Old Croc Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
Unlikely you could just stick an 18 in one of the microscoops...the 15" looks to be a fairly tight fit so I'd guess the baffle is too small.. You would probably also need to adjust the rear chamber size.. I think that a UK soiund called Dubateers use Nightfire designed scoops (a custom design though I think) that look kind of similar to an 18" version of the microscoop, with the baffle angled down to increase effective mouth area. Only seen pics with grilles on though, so hard to see exactly whats going on with their boxes. |
Tekasis
Jeth, seems like Mykeys DubSub or Stipes HOG scoop is what I've had my mind on for months.
You right though, after seeing Dubateers System in Southend the other day, they were using some Nightfire boxes.
Edited by Tekasis - 24 February 2007 at 5:24am |
SmokeyJoe
Tekasis, I never built the MicroScoop's - I built a mockup of the box with scrapwood to see if it would fit in the car, and it turned out too big!
The design is nice though, i've wanted to hear some as soon as i saw the plans . I decided to build the B&C Sub18 - which is just about small enough. - SmokeyJoe/ |
Tekasis
OK SmokeyJoe, I hear the B&C Sub's sound good for what they are & their size, & they do look neat & cute.
