  New Posts New Posts RSS Feed - No more Tuff Cab!?
No more Tuff Cab!?
stevie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 02 November 2025 at 7:36pm
Penn's Armacab seems quite good. It goes on easier and is thicker than Tuffcab. It's difficult to say much more without spending some more time with it. The big downside for me is that it's not semi-matt, as claimed. It's glossy. I've dialled down the glossyness a bit by adding ten percent matte acrylic medium but it's still shinier than the matt Tuffcab.
Jimmer303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimmer303 Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2025 at 9:48am
Penn Elcom has Armacab, I have used both that and TC. They both have their slight quirks. I can get good results with AC, however I have noticed that in the cold it dries a bit streaky and have been using a heated drying tent for better results.
Meat Substitute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Substitute Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2025 at 1:25pm
I got my Warnex and did a couple of bins. Curing was outside under my car port night time temperatures we 10C minimum and it cured ok.
Aldcrofts got back to me eventually by text. I advised them it was too late now and I needed refunding. Shame their customer service is so bad when their product is decent (when you can get it!).
smash-monkY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smash-monkY Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2026 at 7:46pm
Can anyone advise on which brand to buy to match a tuff cab finish? - or is it all similar?
I did a couple of bins with black tuff cab a while ago and they still look immaculate, I need to sand down and repaint the two tops to match, in order to sell - hence looking for a match.
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2026 at 7:58pm
Go to your big paint dealer and ask about agrtutral paint or img speedline etc ask them what the local fair ground business use for paint?
Edited by KDW32 - 25 January 2026 at 8:00pm
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2026 at 9:57pm
Try Raptor. Have sprayed a few things with it and has been good. Its a good substitute to Line-X if you dont want to spend big bucks.
woody2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woody2 Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2026 at 8:30pm
Craftmaster...
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2026 at 1:23pm
Just bought some 18 sound from lean audio and noticed they have some paint called montage
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2026 at 1:28pm
Craftmaster...
Thumbs Up Just googled them. Says they are backed up by HMG paints in Manchester. I used HMG speedline on a refurb and was happy with it.
BAAUDIO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BAAUDIO Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2026 at 11:49am
Hello, I hope you’re all well.
Has anyone here painted directly over Tuffcab, if so which brand of paint did you use and were you happy with the results.
I need to re-coat some cabs and really don’t have the time to sand them back to bare wood. Many thanks.
All the best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2026 at 12:00pm
I've found the Penn paint to be very good and compatible with Tuffcab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BAAUDIO Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2026 at 12:01pm
Fantastic, thank you Stevie, that’s super useful. All the best.
