  New Posts New Posts RSS Feed - Not so micro tapped horn.....AKA...JTH-18
 Post Reply Post Reply Page  123 21>
Beatdaddy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Topic: Not so micro tapped horn.....AKA...JTH-18
    Posted: 17 March 2011 at 3:33am
im making 8 of these for an interactive display at a museum ,they will all play at the same time via midi footswitch..... :)
Edited by Beatdaddy - 09 July 2011 at 12:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2011 at 3:44am
Small 5 inch sony drivers, $4.55 each!
loonie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loonie Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2011 at 10:19pm
Do you plan to build these?
Team DB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2011 at 4:25am
I may change it a little tomorrow, then i'll make 8 of them...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2011 at 2:05am
im building one of these tomorrow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2011 at 1:44pm
this ones better
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2011 at 6:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2011 at 7:00pm
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2011 at 11:33pm
Witch driver is it?
Edited by djyves - 19 March 2011 at 11:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2011 at 11:57pm
ive simmed many drivers, i'll post them up in the morning :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2011 at 12:29pm
i stretched out the plans !
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2011 at 12:42pm
are you going to be using 4?
if you're going to sim in 0.5 pi then EG needs to be 1.41
Edited by mykey- - 25 March 2011 at 12:44pm
