  New Posts New Posts RSS Feed - Not so micro tapped horn.....AKA...JTH-18
 Post Reply Post Reply Page  <12345 21>
Beatdaddy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2011 at 7:15pm
fatail 18 fh500
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2011 at 7:17pm
18 p 1200
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2011 at 7:18pm
sigma pro 18
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2011 at 7:20pm
kappalite lf 15
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2011 at 7:23pm
kappa pro lf 15
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2011 at 7:24pm
delta pro 18a
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2011 at 7:26pm
beyma 21sw1600
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2011 at 7:31pm
rcf 21n451
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2011 at 7:54pm
are you going to be using 4?
if you're going to sim in 0.5 pi then EG needs to be 1.41
so is this the right way?
FlipC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlipC Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2011 at 5:45am
Really - No.
It is an 8 ohm driver so make it 2.83 volts and then if you want to know what it will be with a multiple stack go to Tools > Multiple Speakers and input the desired stack size.
Your 1w1m in HR is on par with the given 98.5
spec. I get right at 100 db at 30 Hz with your data.
I compared 2 of these with a
single Dual 21" B&C (Th221 Clone I did) and it is close. They share the same MAX SPL +/- 1DB but the TH221 Clone goes lower (18 Hz = 126 DB) THOUGH the TH221 is bigger...
I still run the problem of the fact the driver is $500 bucks (US)
and I can build about 4 SS15 TH's for the price of one of those. We are talking 10 plus DB more for the same buck. Though cut off on the SS15 is 33Hz not 20.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2011 at 6:17am
I've got a few mth4654's,I need lower cuttoff.... Dubsteppp bro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beatdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2011 at 6:34am
Edited by Beatdaddy - 27 March 2011 at 6:35am
