  New Posts New Posts RSS Feed - notebook/laptop help
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2018 at 7:26pm
...do you have an optical drive?
Again does this laptop have an optical drive?.. all this can be ignored if you have an optical drive bay.
Most of these 32gb ones do not. I know what you were thinking.
Just looked at a fresh 10 install and it's 30gb, plus a few on hidden partitions
I have seen this issue at least 10 times and only the Asus has a way out without scratch install
So.. make and model please so we can properly debate and conclude on a helpful answer
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2018 at 9:53am
Agreed
I-shen Soundboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I-shen Soundboy Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2018 at 8:18pm
Originally posted by Dub Specialist Sound Dub Specialist Sound wrote:
Part B: select or connect an external storage device.
Where it says <none>, select your 128GB USB drive.
You might as well go through part A as well and delete all the junk clogging up your C drive, and if you want the Pro tip, "clean up system files" as well.  I'll bet there's a 10GB system restore hogging space.  Kill it all.
I've got one of these 32GB drive laptops, free from John Lewis broadband for signing up, so I'm not complaining, even though my eleven year old desktop spanks it.  It gets through the six-monthy update fine if it's got a usb or micro SD card plugged in to use.
A Windows 10 install shouldn't be much more than 11GB, plus another few for the browser, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2018 at 9:49pm
I'm a Windows and 'droid user... but doesn't stop me hating windows... there truly is no real solid reason for Windows 10 to be 11gb inside as a fresh install! Yes a 32gb drive was a stupid idea from that computer company but if we knew the make and model we could suggest other ways to help rather then just removing all traces of restore points that may help at some point.
I'm hoping it's a laptop with an optical drive so we can cure the problem once and for all and get him away from that stupid 32gb drive he's using...
Post Options Post Options   Thanks (0) Thanks(0)   Quote I-shen Soundboy Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2018 at 10:32pm
It's an Asus (from the screen background) and no, there won't be an optical drive in a laptop with a 32Gb eMMC hard drive, or indeed any laptop you could buy new today.
Deleting system restore points is really not a problem; when was the last time you used one?
OP only has to clear 0.8GB from his hard drive and use a USB drive with at least 10GB orf space to get the update to install.  Follow the sodding instructions on the screen...
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2018 at 7:44am
Many of the Asus have a ready made 2.5" expansion on the bottom. No need for Optical/hdd caddy things.
 I ain't knocking 10 for it's foibles, less than an hour installed and completely patched, Win7 has so many patches it takes forever and fails if not 4gb or more RAM (64bit), unless you do them in bits. Also 10 will run on 2gb, 7 is shagged unless on 4 or more, plenty more if you use AV.
 Worst thing about 10 for me is you cannot monitor the chkdsk progress (tried all the switches), used to see bad sector added then shut off and move on with new drive. No more, just a bad representation of %, oh and it really does seem to have wireless printing driver issues too.
 On subject, does it have an expansion slot underneath?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2018 at 3:05pm
...tons of laptops have optical drives still on the market!
Netbooks and notebooks tend not too.
Can we get the model so we can solve this much much quicker please...
Like any problem on here we need full information to solve the problem at hand or we are just stabbing in the dark and making this tread 20x longer then it needs to be... we are already nearing the end of page 2 and we have little to bugger all info on WHAT laptop we are fixing, or at least trying to help fix
Post Options Post Options   Thanks (0) Thanks(0)   Quote I-shen Soundboy Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2018 at 11:09pm
You're quite correct: A quick look at the Currys website shows five models with a dvd drive, of the four hundred odd listed.
However, none of the Asus models with a 32GB eMMC are in this category, so I think we can safely assume there's no optical drive.
Have we hit page three yet, or has Dub Specialist traded in his new computer for a Mac?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2018 at 11:22pm
Mac? How dare you!!!!  Only thing those things are useful for is wiping and installing windows... and even that isn't THAT much of an improvement.
So have we determined if it's hard soldered to the MB or there's a slot we can upgrade with... again, a model number would really help here
Post Options Post Options   Thanks (0) Thanks(0)   Quote I-shen Soundboy Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2018 at 12:00am
If it's a 32GB eMMC, it's hard soldered.  64GB ones are removable.
Any usb, SD card or micro SD can be used as additional storage (which he'll need) but he's also got to clear up some space on the C drive.  The update will download to and unpack on the usb/SD/microSD, but it needs sufficient space to install on the C drive.
Really, following the instructions on the screen (shot) to clear space on C and using an external memory chip will allow the windows update to install without any problems.  I've done exactly the same with a 32GB Lenovo and a 64GB usb key.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2018 at 10:54am
Sorry for late reply, had problems signing in bcus of all changing password words
ect
so back on my very old toshiba laptop now again...
UPDATE
i taken the thin g back for a full refund, cant be messing about with it tbh, and too the person about read the thing , it cannot instaill anymore , it impossaible even with i deleted any app game i cud , and still wasnt enough memeory still
can confirm its a
ASUS VivoBook E406 14 Inch Celeron 4GB 32GB
thanks for all your help still....
so now looking for a proper laptop again
