Oberton 15MB600 VS 15NMB500 for Mid Bass |
insguy
New Member Joined: 16 September 2019 Status: Offline Points: 7 |
Posted: 23 September 2019 at 10:36pm |
Hello,
I want to build two reflex speakers to use as Mid Bass/"Kick" for a 4 way soundsystem. The goal is to get pretty low with the reflex so I can cut the subs (probably 18" scoops) pretty low and also use the reflex for the "full" bass range when playing a small house party setup without any subs. I already know that for proper kick bass I should look into building horns like HD215 but I don't need the punchiest kick because I mostly play 70s roots anyway. The sound I am looking for should be rather warm. So I think I finally found a design that I am happy with (similar to a 15" G-Sub cut in half) so a rather large cabin. I think PD 156 is a good choice for this design but I heard good things about Oberton and they are cheaper so I want to give them a shot. I am torn between the http://oberton.nl/winkel/15-inch-speakers/130/ - 15MB600 and the http://oberton.nl/winkel/15-inch-speakers/15-nmb-500/ - 15NMB 500 . If anyone can elaborate why one would be better than the other for my type of cabin I would be very happy. If the answer is simply "just run them in the simulator" I guess I'll finally have to deal with that software :P thanks all!
JonB67
The answer is "just run it in the simulator"
WinISD is what i use. Its pretty simple. Without simulating them you can neither compare them nor see what volume and tuning (and therefore port size) you need for that specific driver. I certainly wouldn't put the effort into building a cab on the off chance its the right size when its relatively easy to get it spot on.
paulus
Old Croc Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3181 |
buy my pd154s lovley kick drivers hahah ;)
TRENDSETTER SOUND SYSTEM
