Oberton 18XB1600 + Foundation Scoop |
Post Reply | Page <1234 7> |
Audio_Stash
Registered User Joined: 02 June 2014 Location: UK Status: Offline Points: 245 |
Maybe the Void is a happy medium,...
the oberton and fane are both very musical in a scoop, I hope the void will be the same
nickyburnell
Thanks for the test
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
correct, but no big scoop sound would run let alone thrash 2 of the 3 drivers why.... the specs alone tell a story, they don't cut it.... as stated the the fane and the oberton are not scoop drivers.... do they work, all drivers will make a noise in x cab. xmax has no effect on efficancy or max spl... I no cabs that will chew drivers up regardless of the xmax, and play better / louder / and more musical on smaller xmax drivers... Why well that's down to the design of the cab.... |
app
Old Croc Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
Is that the point of a good driver? Ability to be thrashed with preamp? Wouldnt it work with the fane too but with different preamp settings... |
"what!?"
bee
Audio stash no, my guess with out doing a destruction test, both will blow around the same spl, both drivers would be at there max xmax..... and the spl will be with in 0.07 of each other...
Don't look at the this driver takes x amount off watts more and x bigger xmax.... sensitivity of the driver plays a big part, both fall short in the ideal scoop driver department for me... the v1000 and the pd186 will outperform both, and were not even talking about the big boy drivers for scoops... Edited by bee - 23 March 2015 at 7:50pm |
Audio_Stash
Some guys say oberton is good in scoops you don't.... Its advertised to work in scoops. Having tested myself I can confirm, it definitely does.
Audio_Stash
I'm not claiming its the best. But I am telling you it works, and works well.
Teunos
Sorry Bee, but here you are simply wrong. Generally speaking higher Xmax woofers will simply produce more. Sub 70Hz almost all subwoofers are excursion limited, guaranteed. Sim the Fane and the Oberton in the same design in Hornresp and use the Maximum SPL function. Input correct Xmax figures and maximum power handling and guaranteed you will find the Oberton vastly outperforms the Fane, probably by at least 3dB, which is actually quite a lot.
Best regards,
Teun. |
bee
if your happy great.... driver specs on the oberton are a little suspect and no polar plots, what are they hiding, why not plots.......
has any one benched an oberton..... would be interested to see plot.... |
bee
I agree to a point with you Teunos, but not totally, there are too many things that effect how and when a driver hits xmax in a cab, and power is only one of them things. Chamber size throat size ect will effect one driver different to the next in same cab. So based on driver specs only, I would not use either in a scoop... even if the oberton did perform better comparing it to the fane is a waste of time, I would not use the fane in a scoop... totally wrong cabinet design for it. if I had a monetary budget of the oberton new rrp price, I would buy second hand 1850.... and still have change for a beer in the pub...
bee
both drivers hit there xmax with only 300 watts..... the oberton hit xmax at 50hz 325 watts,
the fane hit xmax at 45hz 300 watts, |
Audio_Stash
Is that free air? I've had both drivers on a 650w amp channel and they barely move.
