Octavius 1560 kick bass horn |
Page 12> |
Augusts
Joined: 07 January 2017 Status: Offline Points: 195 |
Topic: Octavius 1560 kick bass hornPosted: 11 December 2021 at 9:40am |
Hey guys!
I have a project here that I originally designed for a PHL Audio 6201 Mnd driver. The driver has an octagonal shape basket so it is very compact. The enclosure size is 67Wx56Dx43H, it will fit also other drivers but might need some modifying of the box size. The design is a very compact sealed chamber and a compact throat chamber, then a conventional horn begins to expand. The driver sits in the throat chamber so the motor system is well ventilated. It has a pretty low end extension 51Hz -10db. I dont remember the sensitivity because I have lost the horn resp file due to an error - it went blank, that sometimes happens and also the 2d plans are gone, but I could rebuild all of this if someone would find this project interesting. This is a prototype so it does not have any handles and has a little sweat on it :) Here are some photos and a ground plane measurement with HP4 and LP4 filters activated, no EQ. If you have any questions or suggestions drop a comment or PM ![]() |
LjudLahger
Joined: 31 July 2008 Location: Sweden Status: Offline Points: 837 |
Posted: 11 December 2021 at 10:14am |
Looks good!
Augusts
Posted: 11 December 2021 at 10:16am |
Thank you
king david
Joined: 17 January 2007 Location: italy Status: Offline Points: 1329 |
Posted: 11 December 2021 at 4:47pm |
It’s very interesting!
JulianDA
Joined: 29 May 2018 Location: Soest, Germany Status: Offline Points: 156 |
Posted: 11 December 2021 at 7:38pm |
Looks like a fun little cab....great work!
bob4
Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1924 |
Posted: 11 December 2021 at 9:39pm |
Looking great! Very nice work, pity you lost your data!
I am sure many people would appreciate it if you could be bothered with re-drawing and releasing the plan. I think someone was very recently asking for a kick bin that plays high....
Augusts
Posted: 12 December 2021 at 3:39am |
Im gonna do another measurement with filters off sometime soon so we can seee how high it can go but I think this measurement was taken considering the usable freq range when it was as linear as possible- 200Hz being the top emd, I personally think this is how high the kick bin should normally play maybe a little higher even.
Thanks for all the thumbs up- that motivates me reanimating this thing Edited by Augusts - 12 December 2021 at 3:45am |
king david
Posted: 12 December 2021 at 5:32pm |
200hz and no honk would be nice
VECTORDJ
Joined: 11 June 2006 Location: United States Status: Offline Points: 585 |
Posted: 12 December 2021 at 7:20pm |
A+
Augusts
Posted: 13 December 2021 at 8:26am |
OK so I did a simulation of the box
This is with filters on, spl at 1000w aes PHL driver ![]() But the embarassing part is that with filters off, its so bad that I even don't want to show it publicly :D When I designed this box I really did it to have a low end of 60Hz to be able to cross over to infra subs, but later I figured that it is best to have a kick that plays from 80hz and then it can go higher to about 250hz so... I don't know. the RTA measurement looks good but the sensitivity is low. Maybe its not worth bothering further on into this project
Edited by Augusts - 13 December 2021 at 8:27am |
cms nr2
Joined: 12 January 2023 Location: germany Status: Offline Points: 2 |
Posted: 25 November 2023 at 8:19pm |
Hi would it be possible to get the plans or at least some measurements of the enclosure so I can try to re simulate it in hornresp? Would like to build some
Augusts
Posted: 26 November 2023 at 6:05pm |
hey! I am the designer behind this box. Ill try to find some plans for the box, Or try to make a hornresp edit file. The kick was very good with filters on.
Page 12> |
