  New Posts New Posts RSS Feed - Odd pin out
Odd pin out
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Topic: Odd pin out
    Posted: 05 December 2017 at 5:51pm
Hi guys
I've got to make up some odd leads to go from a beta91 to a sennheiser EW300 G3 belt pack. So it's the mini xlr (3pin lemo) to the sennheiser 3.5mm locking jack.
I would just wire it as normal with pin 2 hot and 3 cold. But the pins are labelled diffrently to standard XLRs.
Anyone done this before? Worst case cenario I will just make them up and trial error.
Real world experience please :)
Thanks in advance.
Jace
www.deltastarevents.com
www.dss-audio.co.uk
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2017 at 2:57pm
Labelled different how? Tbh never usually made a difference for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2017 at 3:07pm
Hi Sam,
Have you made up mini XLR - 3.5mm jumpers?
On a standard XLR the 2 pins flat against each other are 1&2 the mini ones they are different.
www.dss-audio.co.uk
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2017 at 4:37am
Senny wireless beltpack mics are wired unbalanced because the beltpacks can be used for both mic and line inputs.
https://sennheiseruk.happyfox.com/kb/article/104-ew-plug-pin-configuration
Edited by Conanski - 07 December 2017 at 4:40am
MattStolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2017 at 10:13am
Bigger issue will be providing enough phantom voltage to power the Beta91, needs 11-52V, i.e. nominal 48V Phantom.
Beltpack with a couple of AA in will not be man enough? Electrets typically work off 5ishV? With 5V bias present, I doubt you would get enough voltage, and effectively it would "clip" early and be unable to cleanly reproduce wave form?
The mini 3 pin XLR drives the preamp stage, this stage may bias the electret capsule within to 5 V, but the preamp may need more volts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2017 at 7:50pm
Thanks mate, That worked a treat all going now :)
I assumed it would be a balanced in to the pack. Wired it to the tip and nulled out the cold to the ground and KA-Pang :)
www.dss-audio.co.uk
