Odd pin out |
jacethebase
Posted: 05 December 2017 at 5:51pm |
Hi guys
I've got to make up some odd leads to go from a beta91 to a sennheiser EW300 G3 belt pack. So it's the mini xlr (3pin lemo) to the sennheiser 3.5mm locking jack. I would just wire it as normal with pin 2 hot and 3 cold. But the pins are labelled diffrently to standard XLRs. Anyone done this before? Worst case cenario I will just make them up and trial error. Real world experience please :) Thanks in advance. Jace |
www.stage2sound.com |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
Labelled different how? Tbh never usually made a difference for me.
jacethebase
Hi Sam,
Have you made up mini XLR - 3.5mm jumpers? On a standard XLR the 2 pins flat against each other are 1&2 the mini ones they are different. |
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2544 |
Senny wireless beltpack mics are wired unbalanced because the beltpacks can be used for both mic and line inputs.
https://sennheiseruk.happyfox.com/kb/article/104-ew-plug-pin-configuration Edited by Conanski - 07 December 2017 at 4:40am |
MattStolton
Bigger issue will be providing enough phantom voltage to power the Beta91, needs 11-52V, i.e. nominal 48V Phantom.
Beltpack with a couple of AA in will not be man enough? Electrets typically work off 5ishV? With 5V bias present, I doubt you would get enough voltage, and effectively it would "clip" early and be unable to cleanly reproduce wave form? The mini 3 pin XLR drives the preamp stage, this stage may bias the electret capsule within to 5 V, but the preamp may need more volts?
jacethebase
Thanks mate, That worked a treat all going now :) I assumed it would be a balanced in to the pack. Wired it to the tip and nulled out the cold to the ground and KA-Pang :) |
