  New Posts New Posts RSS Feed - Odd scoop question
Odd scoop question
tkroeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkroeker Quote  Post ReplyReply Direct Link To This Post Topic: Odd scoop question
    Posted: 08 February 2018 at 7:51am
Does anyone have pics or info on how you ran wire? i.e. from the back to the front and screw hardware to the side walls...lol
I know it should be self explanatory but rattle is what I'm concerned about and the logical way just seems so odd.
Just got in 4 Dayton PA465's and Excited
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2018 at 11:13am
Seen/had/built nuff scoops over the years , thick ,thin baggy tight cable, never heard cable rattling tbh
seen ppl use cable clips to pin down cable, drill hole in rear baffle str8 to driver nothing realy to be conserned about
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkroeker Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2018 at 11:17am
Hmmm, drill and straight through instead of zig zag up and down.
Awesome.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2018 at 11:18am
Yes bro, seen it loads of times,
then it tends to less baggy cable in the front chamber then tbh
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkroeker Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2018 at 11:33am
you rock, Thanks.
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2018 at 11:57am
Drill the hole as close to the cable diameter as you can and seal around it well with silicone. Else pressure will find a way (out)
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2018 at 6:47pm
I hate to be the bearer of bad news but the PA465 is not a good drive especially for a scoop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkroeker Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2018 at 4:45am
we'll see lol. They are in the Garage. The math I did seemed pretty good.
Hemisphere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2018 at 9:47am
Depends what your aim is for the project, really. If you want scoops no matter what and that's your only driver option, go for it but don't expect optimal performance. It's a reflex driver not a horn driver.
Phase 1: Post on Speakerplans
Phase 2: ?????
Phase 3: Profit!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkroeker Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2018 at 10:05am
Bet I got mixed up on what driver I picked... I started with the Omega Pro and the guy thats going to be running them wanted more Xmax and in looking through options.... I was thinking these listed themselves as scoop options but ,, nope. Oh well I will drop them in some reflex and sell them to him lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkroeker Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2018 at 10:41am
So what effect does having a high QES and QTS have.
These are
QES - .62
QTS - .57
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2018 at 9:01pm
Long and short of it, quite a weak motor. Small magnet, low magnetic flux in the gap, not many wire turns in the gap, small voicecoil. You get the idea.
This page was generated in 0.110 seconds.
