  New Posts New Posts RSS Feed - Odd scoop question
Odd scoop question
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2018 at 10:11pm
If you check every in a BR box it calls for a BIG box to get it flat.
tkroeker View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tkroeker Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2018 at 7:12am
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2018 at 12:23pm
Originally posted by tkroeker tkroeker wrote:
So what effect does having a high QES and QTS have.
These are
QES - .62
QTS - .57
Those values tell you, you have bought a cheap car bass speaker, for PA use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2018 at 12:47pm
Quote So what effect does having a high QES and QTS have.
These are
QES - .62
QTS - .57
It does tell you the manufacturer had to cut down on the cost of the driver, and now the driver isn't as usable (for a wide variety of designs) as it would have been with a lower Qts. On the plus side it will handle a decent amount of power (they didn't cut back there).
Quote Long and short of it, quite a weak motor. Small magnet, low magnetic flux in the gap, not many wire turns in the gap, small voicecoil
Actually, just based on Qes and Qts, the magnet could still be huge, due to a large Xmax *(many turns) or a different motor topology. The voice coil could still be large as well, a 6" VC driver can still have a high Qes and the current 3.9" VC isn't actually that small.
Johan
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2018 at 6:33pm
These are
QES - .62
QTS - .57
Johan
It was more intended to be a list of a few possible things than them all being true, but yes I agree.  Low electrical damping generally means weak motor though, however that happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkroeker Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2018 at 6:52pm
Good comments.
I guess the best adds would be until I drop in different drivers, do certain things like...
stay away from XX frequency or.. keep the volume low... stuff like that.
This page was generated in 0.092 seconds.
