Ohm BR system |
Post Reply | Page <1 23456 7> |
djgorey
Young Croc Joined: 29 December 2007 Location: S. Wales Status: Offline Points: 1306 |
That's a fantastic idea! I'm annoyed (but not surprised) that I didn't think of it! There's no way I'm lifting my speakers on to the top of my car, but everything else would go. The bits you mentioned would probably free up enough space to get everything else inside. I was looking at a trailer, but even second-hand, having to get a tow-bar and sit the driving test means that I'd be looking at a few thousand and I really can't justify based on the number of gigs x the ££ per gig! Time to hunt eBay for "Volvo 850 roof rack" and "Volvo 850 sized tarp" Edit after doing some looking... Thule Easybase looks ok - still need a tow-bar, but you can get a bag, or I can just stack my flight-cases on it and strap them down well. Further edit: Roof rails are definitely the best option. Thank you Markie
Edited by djgorey - 17 May 2019 at 5:39pm |
Gaffa tape is like the force in Star Wars - there's a dark side and a light side and it holds the universe together
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
i used to run 18" bins but took up a lot of space and 45+ kg quite big i switched to 15" a lot more compact sound much better with more types of music mite lose a little extension but deffo worth it
djgorey
Yeah no! I haven’t even plugged in the bins yet so not selling them just yet! I just need some imagination on the packing!
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
just get a roof box ,they fit on quite easy and you can leave all the stands , booth ect loaded up ,usually cheap on ebay s/h
GOD TOLD ME TO DO IT !!!!!
TMH Music
Young Croc Joined: 07 April 2011 Location: London Status: Online Points: 635 |
Check your car license, if you’ve passed your test, you’ll notice you have entitlement to tow an unbraked trailer under 750Kg. Additional test only required for trailers above this gross weight. A small open trailer, like the one linked to below, would be fine to carry a pair of bins, with a tarpaulin over them. Tow bar and used trailer should be doable for £500 ish.
Nothing is foolproof because fools are so ingenious
jammin75
are u usin front seat and foot well ??
djgorey
Naturally! I’m checking my licence now
djgorey
Yes, I can 😊
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 884 |
Hehe, that jogged my memory. Back in the 60s when I lived in Ealing, West London, I remember a DJ (not even sure that I knew his name at the time, deffo not now) doing the Feathers in Ealing Broadway. End of the night he loaded up and then put two Selmer Goliath 18" bins onto the roofrack of his Jaguar mk2, and drove off with the car swaying from side to side.
If your vaccinations were mandatory and nobody in your class had measles,
then you know that you're not a Millenial kid.</f |
djgorey
Oh that’s pure class! My car is nowhere near as cool as a Mk II
TMH Music
In fact, you are right on the switchover point!! If you passed your test before January 1997, you should have category B+E which entitles you to pull a “heavy” braked trailer. In fact even if you passed after January 97, you still can, so long as the gross train weight is under 3500Kg. Doing a quick look up, your 850 has a gross weight of around 2100Kg (check this first), so you could still, theoretically (again check the specs of your particular variant) tow a 1400Kg trailer, with your license!!
djgorey
Annoyingly, I passed my test in October 1999. Even so, I don’t think anything that big. A trailer that is just big enough to get the bins in would be perfect. I can leave them in the trailer in the garage and just hook it up when I need to use them. Everything else easily fits in the car. Plus a tow-bar is just analogue parking sensors. My brain has been working on it overnight and I have another plan to try this morning (and it’s not “swap the car for a Transit”. I made that mistake with my SAAB 9000)
