  New Posts New Posts RSS Feed - Ohm BR-15S
Ohm BR-15S
Majestic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Topic: Ohm BR-15S
    Posted: 01 August 2014 at 10:16pm
Just bought some for £200 a piece. Is that a good deal? They were meant to be £2000 new.
Does anybody have any experience with them and do you know what they are loaded with? They do sound good and they weigh a ton!
Edited by Majestic - 02 August 2014 at 6:13am
BOOMBOOMPOW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BOOMBOOMPOW Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2014 at 7:58pm
They are a DE700 B&C 1.4" compression driver on the same horn flare as used in the OHM TRS212
the 15" drivers can be B&C or Fostex or maybe something else for the 15"
Good cabs but very very heavy
Its sounds Great
lickweed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2014 at 9:27pm
Excellent cabs,still have the double 15" version BR-30S.
+1 B&C DE700 plus 15" b&c or ohm own in last versions.
They have honey comb bracing so a bit heavy,but well worth the extra weight.
http://www.liquidsound.co.uk/
THECANDLEMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THECANDLEMAN Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2014 at 2:51pm
Yep
Got a pair if br15 tops
Comp on them is lovely
And always shock me how much they can do/cover
Motion Systems - Void Airmotion, Airten & Stasys 218 With Powersoft DSP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 7:53pm
opened them up and confirmed the b&c comp, 15" isnt b&c though.
i presume its the fostex. does anyone have any idea which model they are?
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 8:30pm
it may be a fostex L469
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 9:49pm
It is Ohms own 15" driver built in the factory at Knutsford
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 10:01pm
ok cheers, but the chassis looks just like the fostex, it is painted silver instead of the black L469
Djdarch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Djdarch Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 10:33pm
ive got a pair of br12 and they have a fostex 12 in them .....quite old they are thoiugh
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2014 at 10:10am
If the chassis legs are triple spoked then it is the Ohm driver, if not then it probably is an ancient cabinet with a Fostex inside---These are quite rare in 15" Ohm cabinets.
dylan-penguinmedia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2014 at 1:59pm
Send me the serial no and I'll check what it's supposed to have in there for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2014 at 5:57pm
thanks for the info robbo.
thanks dylan, will check serial numbers next week
