Ohm BR-15S |
Post Reply | Page 12> |
Majestic
Young Croc Joined: 16 March 2011 Location: Glasgow Status: Offline Points: 1290 |
Posted: 01 August 2014 at 10:16pm |
Just bought some for £200 a piece. Is that a good deal? They were meant to be £2000 new.
Does anybody have any experience with them and do you know what they are loaded with? They do sound good and they weigh a ton! Edited by Majestic - 02 August 2014 at 6:13am |
BOOMBOOMPOW
Registered User Joined: 22 June 2011 Location: NORTH Status: Offline Points: 335 |
They are a DE700 B&C 1.4" compression driver on the same horn flare as used in the OHM TRS212
the 15" drivers can be B&C or Fostex or maybe something else for the 15" Good cabs but very very heavy |
Its sounds Great
lickweed
Old Croc Joined: 02 May 2009 Location: leyton Status: Offline Points: 2489 |
Excellent cabs,still have the double 15" version BR-30S.
+1 B&C DE700 plus 15" b&c or ohm own in last versions. They have honey comb bracing so a bit heavy,but well worth the extra weight.
http://www.liquidsound.co.uk/
THECANDLEMAN
Young Croc Joined: 08 December 2008 Location: CentralScotland Status: Offline Points: 1144 |
Yep
Got a pair if br15 tops Comp on them is lovely And always shock me how much they can do/cover |
Motion Systems - Void Airmotion, Airten & Stasys 218 With Powersoft DSP
Majestic
opened them up and confirmed the b&c comp, 15" isnt b&c though.
i presume its the fostex. does anyone have any idea which model they are? cheers |
Majestic
it may be a fostex L469
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Online Points: 4226 |
It is Ohms own 15" driver built in the factory at Knutsford
Majestic
ok cheers, but the chassis looks just like the fostex, it is painted silver instead of the black L469
Djdarch
Old Croc Joined: 10 November 2005 Location: Newark, Notts Status: Offline Points: 1989 |
ive got a pair of br12 and they have a fostex 12 in them .....quite old they are thoiugh
Robbo
If the chassis legs are triple spoked then it is the Ohm driver, if not then it probably is an ancient cabinet with a Fostex inside---These are quite rare in 15" Ohm cabinets.
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
Send me the serial no and I'll check what it's supposed to have in there for you.
Majestic
thanks for the info robbo.
thanks dylan, will check serial numbers next week |
