Ohm TRS Components |
Post Reply | Page 12> |
PAHS
Registered User Joined: 10 June 2017 Status: Offline Points: 35 |
Posted: 30 June 2017 at 1:14pm |
Hi all,
Could anyone tell me the latest ohm trs 218 and 212 components and specs please? Having difficulty in finding out what drivers and components are in them? Thanks |
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
ohm drivers tend to be made in house ,with the compression drivers being mainly bms
GOD TOLD ME TO DO IT !!!!!
PAHS
Thanks Krazyneil - you don't happen to know the specs by any chance?
krazyneil
ohm wont release any specs of there drivers I wouldn't of thought as there made specifically for there usemaybe email them and see if they can help
what do you need them for ? if you have the drivers you can measure them if your trying to copy them then your out of luck ,as getting the drivers might be a problem and you could just as easy buy some Edited by krazyneil - 01 July 2017 at 5:02pm |
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2732 |
Why do you need them?
And I do have some stuff somewhere but won't share unless good enough reason given. |
PAHS
Hi Pasi,
I am going g to look at a used system and hopefully buying tomorrow, with that in mind I want to ensure my limiters etc are set up correctly before use by obtaining the specs to work out my limiter settings correctly. So will be running 4 x ohm trs 218 and 2 x 212, purpose is simply to set up limiters and crossovers correctly. Thanks in advance, |
thirtha
Registered User Joined: 12 November 2014 Status: Offline Points: 77 |
OHM is with the Indians now. God save us all (and the Queen too)
Pasi
Which amps & DSP you are using? |
Pasi
Only 75% of it |
PAHS
I'm looking to utilise my current amps which is a
QSC PL236 @ 1100w per channel into 4 ohms for the tops and 2 x QSC PL4.0 @ 1400w per channel into 4 ohms for the bins. Just not sure for the the ohm speakers these are going to provide enough juice to get the most out of them? PA collected this morning, and really want to setup to make sure they deliver the best possible!! |
PAHS
Sorry DSP is Behringer UltraDrive
Edited by PAHS - 02 July 2017 at 8:01pm |
Pasi
As long as your sub amp doesn't clip, it's fine and pretty much gets the best out of the cabinets. For tops, calculate limiting to 500W RMS to be safe, or -4dB on the amp.
